turbo conversion of a 2.5 N/A derfender
I don't know much about the diesel side and am happy to be corrected but I think this is basically what Land Rover did with the early 2.5TD as it is the same block as the 2.5N/A. In turbo form suffers from cracked pistons and bottom end failures. The engine was superseded by the 200TDI
yep as far as i know they took the same engine, same internals everything and slapped an airresearch turbo on.
i recently rebuilt one in our old 90. was a d reg, hadnt blown up (as most did lol) but the pistons were a right old cracked mess.
but anyway, back to the point, it runs like an absolute dream now. purrs like a kitten (am i mentally disturbed for rebuilding a 19J??)
i think all that was added was the turbo, obviously accompanying hoses, oil feed and return to sump, and im not 100% if it needs a new pump or just something adding to the pump to adjust fueling on boost
i have photos somewhere if they'll help you at all
might be easier just to buy a 19j engine though, and if you were going to do that, probably a tdi would be more sensible (ps, 200s are better than 300s ;) )
jim
Think that they have different pistons in the turbo version that can handle the higher temps if I remeber right. You also need an oil feed for the turbo - think that you can drill the block for this.
I will have a turbo 2.5 d for sale in the next few weeks - can be heard running/test driven. 77k miles, runs fine. if your interested - pm me.
Adrian
Differnt block casting (turbo take off) which has differnet main bearing housings.
Pistons, manifolds, fuel injection pump are also different.
Cracked pistons are due to combustion abnormalities - Ie overheating and/or faulty fuel injection equipment.
Correctly installed, maintained and keep a turbo diesel cool and it will last as long as any other diesel engine.
FridaT
www.turner-engineering.co.uk
