ECU extension
Guest diesel_jim
You can buy the extension looms from dastec suppliers (dare i mention them.... scrapiron) but Allisport do them too, probably cheaper as well!
or you could buy the plugs and make your own
anyone know where you can buy the plugs from? seems silly paying through the nose for a ready made set.
cheapest place I found was here..
Vems shop
by looms, plus pcb connector. straighten pins on pcb connector and solder on 72 times ;) and then encase pcb connector in resin. It will still cost ~90 in parts
Cheers
Steve
  • 1 month later...
Thanks Jim - still a rather large chunk of money!
Agreed!
I've been looking for a kit for my 2000 TD5 :(
I've heard that sealing the ECU in a box and then using a breather to reduce condensation might be the way forward...
Has anyone gone down this route?
Would be intrested to know further....
