goaty Posted February 7, 2008 Share Posted February 7, 2008 Hi all, I have a disco 200tdi in my 90 and up until recently i ahve never thought about using my glowplugs, so much to that point they arent even connected. Now i have gone to see if they work etc it appears that i am not getting any power to the plugs. I tested the cable coming into the engine bay onto the first plug but the volt meter showed nothing at all. Anyone have any idea as to what could be wrong and where to look?? Relay maybe? but where is it. laso couldn't see a fuse slot for them. cheers in advance joe Quote Link to comment Share on other sites More sharing options...
chris_mack Posted February 7, 2008 Share Posted February 7, 2008 Hi all,I have a disco 200tdi in my 90 and up until recently i ahve never thought about using my glowplugs, so much to that point they arent even connected. Now i have gone to see if they work etc it appears that i am not getting any power to the plugs. I tested the cable coming into the engine bay onto the first plug but the volt meter showed nothing at all. Anyone have any idea as to what could be wrong and where to look?? Relay maybe? but where is it. laso couldn't see a fuse slot for them. cheers in advance joe if it is a retro fitted disco 200tdi into a TD or NA 90, then chances are the plugs are wired directly to the ignition switch as there is no relay on the older 90/110s. So unless someone added a relay when they fitted the TDI it wont have one. You know you have to hold the key halfway between IGNITION and START to heat the plugs? Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2008 Share Posted February 8, 2008 Info here on how to connect using the correct timer relay. Quote Link to comment Share on other sites More sharing options...
goaty Posted February 10, 2008 Author Share Posted February 10, 2008 Hey, yeah it is a retro fit and yes i do know how to use them, i will have a read of the link and see whats what. thanks for the replys. joe Quote Link to comment Share on other sites More sharing options...
