smo Posted February 8, 2008 Share Posted February 8, 2008 I need to remove the outer wing skins to fit a roll cage on my 90 - having only done this before on a written off vehicle i have no idea how it should be done without using an angle grinder as i did previously!!! Can you gents advise please Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2008 Share Posted February 8, 2008 Remove the flexible wheel arch, use a pin punch to knock out the fastener centres, use 13mm spanner/socket to undo the bolts at the flange & bulkhead & 1 long bolt at lowest front end to chassis, remove/disconnectthe repeater flasher & lift skin panel from vehicle. Quote Link to comment Share on other sites More sharing options...
