bushwhacker Posted February 8, 2008 Share Posted February 8, 2008 I need new adjusters on the rear of the 110. I have seen a kit from one of the parts suppliers and it looks a good job but when replacing the old ones do they tap out or does the top need grinding off? To let the cam come off the backplate. Then I assume the new ones need hammering over (cant think of the right word) and then a spot of weld, belt and braces style. Any thoughts or directions would be appreicated. Mark Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2008 Share Posted February 8, 2008 the LR kit is RTC3176, I'm not sure how they fit into the backplate picture of the kit here http://www.lrseries.com/shop/product/listi...JUSTER-KIT.html Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted February 8, 2008 Author Share Posted February 8, 2008 Yes that is the kit alright, but I have seen them much cheaper they are more than likely pattern parts but should do alright. I am still interested in finding out how the old ones come out and the new ones go in. I have managed to get a 2 backplates 1x 109 1x 110 slight difference in them though to put on if I cant sort out the adjuster kit. The 110 is up for MOT 11/3 so I still have some time but do not want to leave it too late. Mark Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2008 Share Posted February 8, 2008 I think the old adjusters have to have the snail cam pin ground or filed off. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 9, 2008 Share Posted February 9, 2008 You cut the old snail adjusters off. The kits I have used have 2 different size snails and you have to use the same size as your old ones. Les. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted February 9, 2008 Author Share Posted February 9, 2008 Ok. Can I assume the new ones need hammered over to keep them in place. I was thinking of putting a small snot of weld on also when I get that far. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 9, 2008 Share Posted February 9, 2008 The whole assembly is held together by a bolt that normally comes pre-locktited. I have known them come undone though, so a blob of weld might be a good idea. Les. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted February 9, 2008 Author Share Posted February 9, 2008 Cheers Mark Quote Link to comment Share on other sites More sharing options...
