disco tony Posted February 9, 2008 Share Posted February 9, 2008 as title but renewed belt Thursday! now slipping again. I think the pulleys are worn on their sides. Can I get crank and pas pump pulleys? or is there an oversize width belt available? Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2008 Share Posted February 9, 2008 Tell me which engine & I'll be able to give you the part numbers for the pulleys or just fit a new belt, it should drive on the sides of the pulleys & not touch the bottom of the pulley V channel Quote Link to comment Share on other sites More sharing options...
disco tony Posted February 9, 2008 Author Share Posted February 9, 2008 I'm the same as you Ralph, (def. 200tdi 1990). Got new belt Thurs because I was fed up with the squealing. Started squealing again today!! Tried tightening and noticed it is running in the pulley vees (about 2mm below crest). Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2008 Share Posted February 9, 2008 PSP pulley is ETC5783 3 groove crank pulley was ERC6859 Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 9, 2008 Share Posted February 9, 2008 The PAS belts are slightly wider then the alternator ones... You probably have the narrow one and it's not gripping because the v in the pulley wheel is too wide.... (Ask me how I know...) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 9, 2008 Share Posted February 9, 2008 OK I will, how do you know, Neil ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2008 Share Posted February 10, 2008 Tony, if you have the 3 groove crank pulley already, the PSP belt fits in the front groove & alternator/water pump belt fits in the rear groove, centre groove is for the air condition pump. pics of my engines 3 groove pulley. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted February 10, 2008 Share Posted February 10, 2008 As above it sounds like your belt is too narrow- Power steering pump one should be 13mm wide. The alternator and water pump belt is a thinner one- about 9 or 10mm wide only. Both the pulleys are available separately but they are unlikey to wear out. Shrek Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 10, 2008 Share Posted February 10, 2008 OK I will, how do you know, Neil ?Mo Well Mo.... It's not a long story... I got a belt from Halfrauds that was the right length, used it and it slipped.... Went to a LR spares place, got the right belt, which dare I say was fatter, and once fitted it worked and didn't slip. Since then of course, I've pulled the engine out so can't offer you moving proof of my experiment, but if you want to buy the engine, you can try it for yourself ! Neil Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 10, 2008 Share Posted February 10, 2008 Well Mo.... It's not a long story...I got a belt from Halfrauds that was the right length, used it and it slipped.... Went to a LR spares place, got the right belt, which dare I say was fatter, and once fitted it worked and didn't slip. Since then of course, I've pulled the engine out so can't offer you moving proof of my experiment, but if you want to buy the engine, you can try it for yourself ! Neil I'll give you a fiver and take a chance, Neil. Mo Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 10, 2008 Share Posted February 10, 2008 I'll give you a fiver and take a chance, Neil. Mo When you coming to collect ?? Quote Link to comment Share on other sites More sharing options...
disco tony Posted February 11, 2008 Author Share Posted February 11, 2008 I got the belt from a very reputable dealer, (Christian autos Bristol), so dont think it's the wrong un. Also ran fine for 3 days. My suspicions are that the pulleys are knackered as I let the squeak develop for a couple of weeks! I'm going to replace pulleys this week and see how it goes. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 11, 2008 Share Posted February 11, 2008 I got the belt from a very reputable dealer, (Christian autos Bristol), so dont think it's the wrong un. Also ran fine for 3 days. My suspicions are that the pulleys are knackered as I let the squeak develop for a couple of weeks!I'm going to replace pulleys this week and see how it goes. Pull the belt, clean the pulleys with a strong solvent and some sandpaper. Make sure the belts are not bottoming. Then it should be fine. Pulleys don't wear out. Are you sure you have it tight enough? A new belt MUST be retightened after a few days. That is normal, as it will bed in. Quote Link to comment Share on other sites More sharing options...
