wkw90 Posted February 10, 2008 Share Posted February 10, 2008 Anyone Know were i can get a crankshaft reground in the Hertfordshire area ?? Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Anybody out there Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 10, 2008 Share Posted February 10, 2008 I used to use an engineering place in Stotfold just north of Hitchin but there are plenty of others - take a look in Yellow pages. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 10, 2008 Share Posted February 10, 2008 Ring around for the price of a new crank. Mine was for a 200TDI and was only a couple hundred quid. At least you know it's new then Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Just found this on RPI website. Re-grounded Crank and new bearings, new piston rings, new mains bolts, new oil pump gears, gaskets as required, the Crank is ground 10/10 to ensure RPi highest standards. £295 . seems ok Paul Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Ring around for the price of a new crank. Mine was for a 200TDI and was only a couple hundred quid. At least you know it's new then [/quoteHows my locker coming ? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 10, 2008 Share Posted February 10, 2008 Need my car mobile till the 17 Feb then it'll be pulled out the next day so will be avail from the 18ish give or take a day for weather. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Need my car mobile till the 17 Feb then it'll be pulled out the next day so will be avail from the 18ish give or take a day for weather. At least then ill have 1 thing in working order Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 10, 2008 Share Posted February 10, 2008 I must admit. Looking at all your posts recently you're going for a full on repair session. It will be good when it gets there. I was like that when I first got my 90. Just got to stick with it and keep going. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted February 10, 2008 Share Posted February 10, 2008 Just found this on RPI website. Re-grounded Crank and new bearings, new piston rings, new mains bolts, new oil pump gears, gaskets as required, the Crank is ground 10/10 to ensure RPi highest standards. £295 . seems ok Paul Bear in mind that that is a 2nd hand crank of unknown origin - Check threads, keyways / seal and pulley seating surfaces before you haul your motor apart.. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Bear in mind that that is a 2nd hand crank of unknown origin - Check threads, keyways / seal and pulley seating surfaces before you haul your motor apart.. It may be a bit late for that as the engine is spread between the front room and spare room , and the crank i have has some really deep score lines on it .. see photos Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Just found this on RPI website. Re-grounded Crank and new bearings, new piston rings, new mains bolts, new oil pump gears, gaskets as required, the Crank is ground 10/10 to ensure RPi highest standards. £295 . seems ok Paul Any thoughts on this ? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted February 10, 2008 Share Posted February 10, 2008 Have you priced a new crank? I use Bearmach for all my parts. Very good on price. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Have you priced a new crank? I use Bearmach for all my parts. Very good on price. Just had a look at a new one from Bearmach just over £900 Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 10, 2008 Share Posted February 10, 2008 http://www.ihertfordshire.co.uk/profile/23...-Transmissions/ Not sure if they do it, but worth giving them a ring. They are extremely helpfull, as well as reasonable pricing!!! Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted February 10, 2008 Share Posted February 10, 2008 It may be a bit late for that as the engine is spread between the front room and spare room , and the crank i have has some really deep score lines on it .. see photos That has led a hard life, but I've seen worse............................ I doubt whetrher the score is motre than 10thou deep...........I suspect the the bigends have also worn slightly oval............ have you measured the journals That crank needs a 10/10 regrind..................... about £50 (ish)........... Ian Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 That has led a hard life, but I've seen worse............................ I doubt whetrher the score is motre than 10thou deep...........I suspect the the bigends have also worn slightly oval............ have you measured the journalsThat crank needs a 10/10 regrind..................... about £50 (ish)........... Ian How would i go about measuring them ? Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted February 10, 2008 Share Posted February 10, 2008 You measure the journals with a micrometer .................. the measurement is to 1/10 of a thou............... I couldn't build an engine with using internal & external mic's, plus load of other measuring gear ......... but I am also a fussy barsteward. I guess your best plan is to take it to an engine machine shop and let them do the business ................ far cheaper than a new or recon crank. Buy your shells form one of the many V8 part suppliers ...................... I don't know of any machine shops in Herts as that is not my locity ................. but Mo might ............drop him a pm........... Ian Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 10, 2008 Author Share Posted February 10, 2008 Thanks to all for your advice . WALFY is going to find out the price of a new one for me ( such a nice chap ) Quote Link to comment Share on other sites More sharing options...
