disco_al Posted February 11, 2008 Share Posted February 11, 2008 basically a friend was driving her td5 disco 2 auto along yesterday, when all power was suddenly lost. it happened quite suddenly, without any warning, and now it won't restart...... it will turn over, and it sounds like it's trying to fire, but it's as if there is not enough fuel getting through, anyone had any similar experiences (it's a 2000 model if its any help) cheers all Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 11, 2008 Share Posted February 11, 2008 Fuel pump is a possibility - can you hear the hum of the pump running when you switch the ignition on? should come on for a while then switch off if the engine is not started. Think it is about 30 sec from memory. Quote Link to comment Share on other sites More sharing options...
Orange Posted February 11, 2008 Share Posted February 11, 2008 Didn't hit a bump and knock out the inertia switch did she?? Sounds like the exact same symptoms that mine had after a numpty took my front corner off!! Quote Link to comment Share on other sites More sharing options...
