wildrover Posted February 11, 2008 Share Posted February 11, 2008 anyone tried out the modified NAS lamp plinths from ''bolt on bits'' on their 94 on defender, are they as good as they seem with no mods to bodywork in particular the rear tail lamps Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2008 Share Posted February 11, 2008 I haven't got any but it looks a neat solution. Quote Link to comment Share on other sites More sharing options...
ibexman Posted February 11, 2008 Share Posted February 11, 2008 Have you got a link Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2008 Share Posted February 11, 2008 bolt on bits ebay shop - front plinths & rear plinths Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted February 11, 2008 Share Posted February 11, 2008 I have almost completed fitting them to The Beastie. Cutting out the shapes needed with jigsaw was tricky - and do wear safety glasses. At one point I could not lay my hands on mine - i.e. they were not under my nose - so went ahead and had a very lucky escape and a very sore eyelid for a week or so. Never realised near molten aluminium could be so hot! I found using a dremel sanding disk worked quite well finishing off the jaggy edges. Also taking your time (not one of my strong points when actually started) is well worth it. Very pleased with effect but I wish the quality of the bulb holders was rather better - mine were Wipac from Paddocks. Cheap as chips and it shows!! Still have rear tail/stop to fit. My next step is to put LED units in place of the bulbs once I have worked out if I need any extra bits to deal with voltage etc. Well worth doing Malcy Quote Link to comment Share on other sites More sharing options...
Litch Posted February 11, 2008 Share Posted February 11, 2008 I think what Wildrover was getting at was that Bolt On Bits manufacture & sell a plinth which fits straight on without any modification to either the panelwork or the plinth itself. I fitted NAS lights to my 90 back in 1990 and was happy to drill my nice new panelwork but I know there are many who would not want to do this and opt for re-shaping of the plinth instead (rather more time consuming and you have to be careful when trimming the material that you don't take too much off). What this firm have done is to manufacture a different plinth which alows the lights to bolt straight without carrying out either of these tasks. I must say that had they been available 8-years ago I might have been tempted, they certainly look ok and the chap who manufactures them states that they are the same material & colour as the normal ones. I guess you could buy a single unit and check it out? "Very pleased with effect but I wish the quality of the bulb holders was rather better - mine were Wipac from Paddocks. Cheap as chips and it shows!! Still have rear tail/stop to fit. My next step is to put LED units in place of the bulbs once I have worked out if I need any extra bits to deal with voltage etc." I am thinking of replacing mine with the all LED versions rather than just fitting LED replacements. The LED's cover the whole of the back-plate and have a fantastic light output, also there are no issues of poor fitting if you have the cheaper units. Mine are genuine parts and so fitted perfectly but over the years a couple of bulb-holders have corroded however replacements are available from your franchised dealer for just over £1 each so no problems there. There is no need for balast resistors when using LED's in place of the normal bulbs in the side/tail, indicator or fog lamps but you will need them for the indicators. Alternatively fit an electronic flasher relay. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted February 11, 2008 Share Posted February 11, 2008 Sorry Think I have misunderstood. I do agree that the all over LED units look good. Have not priced them yet so had better start saving! Quote Link to comment Share on other sites More sharing options...
Defender Posted February 11, 2008 Share Posted February 11, 2008 What a good idea.....I think they look really good & as soon as funds allow I'm definately going to try a set so thanks for posting the links! Pete Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 11, 2008 Share Posted February 11, 2008 well i got a rear set for my 07 defender £35.00 very cheap i will post pics as i fit them dan Quote Link to comment Share on other sites More sharing options...
muddy Posted February 11, 2008 Share Posted February 11, 2008 personly i think they look rubish, that lip makes the light unit look far large for my liking. Just my 2p. Will. Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 13, 2008 Share Posted February 13, 2008 well they came this morning fitting took about 20 mins they come with wipac units so use your old led bulb holders as the wipac ones are carp.look very good better light at the back overal a good design well worth the £35 notes they would be better with pei units as OME dan Quote Link to comment Share on other sites More sharing options...
Darren Posted February 13, 2008 Share Posted February 13, 2008 Got any decent pics, Dan? The ones on the BOB adverts are rubbish. As I understand it, these things alter the position slightly when compared to the 'traditional' cut new holes method of fitting? I've got a set of NAS lights in the garage ready to be fitted and could be tempted by these plinths before I start hacking things around - on the front at least. I'll probably fit the rear by cutting the bodywork as they can be kept slightly more inboard that way. I've also got to fit new rear corner cappings at the same time, so a bit of extra faffing isn't a big deal Quote Link to comment Share on other sites More sharing options...
wildrover Posted February 13, 2008 Author Share Posted February 13, 2008 thanks for all the thoughts on the fitting of NAS lamps, now away to order a set of modified plinths and source the full LED lamp units, any you guys suggest a good supplier for the lamps Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 13, 2008 Share Posted February 13, 2008 Hi Darren here some pics taken tonight and one before fitting Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 13, 2008 Share Posted February 13, 2008 after fitting they look very good sorry about the size playing with my birthday present a nikon d40 Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 13, 2008 Share Posted February 13, 2008 darren they do stick out just a tad but its a much better light dan Quote Link to comment Share on other sites More sharing options...
Darren Posted February 14, 2008 Share Posted February 14, 2008 That's great, thanks. I'll definitely get them for the front as they'll save a considerable amount of faffing Quote Link to comment Share on other sites More sharing options...
Venturers SAR Posted February 14, 2008 Share Posted February 14, 2008 We fitted NAS Lights , not easy to fit ; but have a problem with the leaf spring which contact the bulb . several have snapped for no known reason , can only purchase complete unit in the UK . So ordered the bulb holder via a American dealer who advertisers in a Landrover Magazine. Fast service via credit card , reasonable price Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted February 14, 2008 Share Posted February 14, 2008 We fitted NAS Lights , not easy to fit ; but have a problem with the leaf spring which contact the bulb . severalhave snapped for no known reason , can only purchase complete unit in the UK . So ordered the bulb holder via a American dealer who advertisers in a Landrover Magazine. Fast service via credit card , reasonable price that would be due to the wipac units being carp try lep bulb holders i binned the wipac and used the lep ones dan Quote Link to comment Share on other sites More sharing options...
simonb Posted February 14, 2008 Share Posted February 14, 2008 thanks for all the thoughts on the fitting of NAS lamps, now away to order a set of modified plinths and source the full LED lamp units, any you guys suggest a good supplier for the lamps LED indicators: http://www.dun-bri.com/ShowDetails.asp?id=377 LED stop tail: http://www.dun-bri.com/showdetails.asp?id=391 LED side: They don't list one... standard indicator: http://www.dun-bri.com/showdetails.asp?id=373 standard stop tail: http://www.dun-bri.com/ShowDetails.asp?id=390 standard side: http://www.dun-bri.com/showdetails.asp?id=288 Quote Link to comment Share on other sites More sharing options...
smo Posted February 14, 2008 Share Posted February 14, 2008 I've been looking at these for the 200Tdi, however it suggests that with a car of that age i sill need to enlarge the holes, which is a pain and negates the use of these cleverly designed ones, might just as well fit standard NAS ones unless anyone knows different? Quote Link to comment Share on other sites More sharing options...
Litch Posted February 14, 2008 Share Posted February 14, 2008 I stand to be corrected here as I fitted my NAS lights 8-years ago and at my age the old memory starts to play tricks but I am 99.999999% certain that the standard hole is fine and it just needs to be slotted to allow the lamps to be moved inboard slightly (to prevent overlap). Of course there have always been a few people who just fitted the rear lamps to the standard position and allowed the overlap but in my opinion that just looks pants and made the lamps look very aftermarket whereas when fitted properly they blend in very well. Quote Link to comment Share on other sites More sharing options...
phil Smith Posted February 19, 2008 Share Posted February 19, 2008 thanks for all the thoughts on the fitting of NAS lamps, now away to order a set of modified plinths and source the full LED lamp units, any you guys suggest a good supplier for the lamps Hi New to forum but have just bought defender and wanted to personalise it. Liked the look of front NAS lights from Boltonbits on Ebay so bought a front set. 4 plinths, 4 lenses and 2 amber bulbs. Bulbs didnt arrive and 10 days on still have not managed to get a reply from Boltonbits by phone or email. Definate lack of interest. I would not buy from this company again Sorry did not want 1st post to be negative but might prevent somebody else buying something they never receive. Cheers Phil Quote Link to comment Share on other sites More sharing options...
Darren Posted February 19, 2008 Share Posted February 19, 2008 Conversely, I ordered a set of four plinths via their ebay store last Wednesday and they arrived the very next day. It's frustrating, I know, but don't hang a company based on just one transaction. There could be any number of reasons why they haven't responded. Quote Link to comment Share on other sites More sharing options...
JimC Posted February 19, 2008 Share Posted February 19, 2008 Hey Guys - Us NAS guys have problems with the NAS lights holding moisture and creating problems. The lights look good, but LR had to come out with a special boot kit to try and seal them up. Even that didnt work well. The hot set-up over here is to replace the NAS lights with the sealed Rubbolite model 837's - of UK manufacture. They are costly but excellent. There is only one stateside distributor for these lights, but I'm sure you guys could source them easily in the UK for more reasonable prices. http://www.eastcoastrover.com/LED.html I have these lights on my 95 NAS, and I love them - they are a direct replacement for the NAS lens, fitting right into the stock plinth. Quote Link to comment Share on other sites More sharing options...
