red90 driver Posted February 13, 2008 Share Posted February 13, 2008 I have been given the name of a company that will supply hydraulic cylinders to any size / configuration. http://www.steerforth.co.uk/ They have a fully comprehensive DIY catalogue: http://www.steerforth.co.uk/documents/RAMP...h%20Edition.pdf Has anybody used these guys before, and how do the prices compare to other suppliers? For installing hydro assist on the 90, If I am to use a 1.5" bore cylinder, with an 8" stroke, what rod diameter should I use? Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 13, 2008 Share Posted February 13, 2008 Nice web site Red , I bought a DA ram of ebay last week 40mm ID and 25mm rod , With 9" stroke , I have to cut it down to a 7 inch stroke as I want to mount it behind the axle where the stroke is not so great .But for 36 quid I aint to bothered about it if it all goes titsup. Quote Link to comment Share on other sites More sharing options...
najw Posted February 14, 2008 Share Posted February 14, 2008 Steerforth are probably about the best and cheapest supplier of rams around. I have used them many times. The quality is good but the service is (was) slooooow. If you are on a deadline you need to keep the pressure on! Quote Link to comment Share on other sites More sharing options...
simonr Posted February 14, 2008 Share Posted February 14, 2008 I've used Steerforth for loads of odd hydraulic projects - including ram assist and rear steer. I've been impressed with them. If all you want is a simple ram - it will probably be cheaper elsewhere or used. If wou want a one off, made for the job - they are brilliant! There is no simple answer to how thick the rod needs to be - it really depends how much radial force there is (trying to bend the rod). If you were using it in the same way as a rack & pinion steering setup, the drag links are excerting quite a lot of sideways force. Mine works in this way (with a double ended ram) and so I went for a 30mm rod. If you are using a single, double acting ram in addition to the track rod, without any kind of drag-link, 20 to 25mm will be fine. Si Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 14, 2008 Share Posted February 14, 2008 Thanks for the link red. i have been after some new bushes for the mini digger and it seems they stock the lot! Quote Link to comment Share on other sites More sharing options...
red90 driver Posted February 14, 2008 Author Share Posted February 14, 2008 Glad to have been of service, gents and gent-esses. I was looking at doing the same setup as Steve90 with the ram mounted to the drop arm, rather than welding a lug onto the drag link. Quote Link to comment Share on other sites More sharing options...
smo Posted March 11, 2008 Share Posted March 11, 2008 Do Ramparts supply whole rams, their "catalogue" seems to consist of a lot of bits, rods, weldable ends etc, but no actual rams - i don't want to build one and weld it up, I just want to spec it! Quote Link to comment Share on other sites More sharing options...
red90 driver Posted March 11, 2008 Author Share Posted March 11, 2008 no idea! But it would be worth a phone call to ask. I've not used them yet!! Quote Link to comment Share on other sites More sharing options...
smo Posted March 11, 2008 Share Posted March 11, 2008 Got some prices from them for some rams, all off the shelf - cost a bit more than I was expecting (don't forget to add VAT too!) HFR1250200 - £62.32 HFR1250250 - £64.30 HFR2300200 - £81.67 HFR2300250 - £83.97 Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted April 2, 2008 Share Posted April 2, 2008 I bought the hydro assist steering kit from straight forward supplys got arsed around a bit but f**k that......... Its done now.... I took the set up to a local hydraulics agent (hendry hydraulics) (Elgin) who quoted me £40 for them to make the same ram and ends and i have a friend with an engineering company who could've made up the hoses from off-cuts just paying for the ends.... So if SFS had given me dimensions and info i would have been able to do this pretty cheaply..........!!! I dont have the kit fitted yet as am still awaiting delivery of the portals before i can decide on and fabricate a set up..... pics will be posted i expext it too be another 6 wks to 2 months tho..... Quote Link to comment Share on other sites More sharing options...
gsr341 Posted April 2, 2008 Share Posted April 2, 2008 So if SFS had given me dimensions and info i would have been able to do this pretty cheaply..........!!! thats exactally why SFS didnt give you all the info Quote Link to comment Share on other sites More sharing options...
