Fatboy Posted February 14, 2008 Share Posted February 14, 2008 Evening all, I'm in the midst of building the rolling chassis, axles, steering & gearbox done. I placed the gearbox onot the chassis and then noticed the handbrake linkage mount on the chassis is different to the one on the old chassis.... The old one is the pivot which bolts to the chassis. Whereas the new one looks like: Now, I have not seen this before and it ain't the same as the one on my Rangie so anybody got any ideas how I can get the bits to couple it up? Thanks, Quote Link to comment Share on other sites More sharing options...
rtbarton Posted February 14, 2008 Share Posted February 14, 2008 Does this help The vertical rod you can see connects with the handbrake lever. I've not seen one like your original type before! Only one of the holes is used for the pivot shaft, the other is spare Quote Link to comment Share on other sites More sharing options...
Betsy Posted February 15, 2008 Share Posted February 15, 2008 The original in your pic, that bolts to the chassis is a Series 2a chassis type, same as mine, 1966 suffix C. The new chassis is Series 3 type. Just go and buy the S3 bolt, bush and arm. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 15, 2008 Share Posted February 15, 2008 Nut NY607041L Plate 577138 Spacer 577354 Spindle 577137 Circlip CCN112L The original end washer, lever and bush are the same as late 2a/S3 Quote Link to comment Share on other sites More sharing options...
Fatboy Posted February 16, 2008 Author Share Posted February 16, 2008 Fanstastic help, many thanks, I'll source new bits just to keep it robust. Apologies for my tardy response I've been incomunicado in the Atlantic Quote Link to comment Share on other sites More sharing options...
