viorelluta Posted February 18, 2008 Share Posted February 18, 2008 Hi All, I just bought a set (2pcs) of additional fog lights from Hella, with all necessary wiring, relay, switch etc. They are oval-shaped. Now I am not sure where to install them - either on the horizontal roof rack bars or on the front bumper. My car does not have an A-bar, nor factory-fitted fog lights. If I install them on the roof I don't know how to pull the power cable inside the car. If I put them on the bumper, they are exposed to direct hits. Have you done something like this? How? Thanks Viorel Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 18, 2008 Share Posted February 18, 2008 Fog lights should really go under the bumper , and spot lights above . Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted February 18, 2008 Share Posted February 18, 2008 Fog lights should really go under the bumper , and spot lights above . As above.. Fog lights should be fitted as close to the ground as possible. This is to prevent glare being shone back at ya in the fog. Quote Link to comment Share on other sites More sharing options...
viorelluta Posted February 19, 2008 Author Share Posted February 19, 2008 OK, then I will mount them on the bumper. I guess I'll have to remove the bumper first. Do you have any idea which is the best (easiest) path to follow in order to get the wire into the dashboard? What about a place to install the switch? Thanks, Viorel Quote Link to comment Share on other sites More sharing options...
