auf_wiedersehen_pet Posted February 19, 2008 Share Posted February 19, 2008 Hi All, I'm looking for a new front driver's window run rubber/glazing strip/weather strip - the U shaped rubber strip which sits inside the door frame. The Disco part manual does not give a number - so I am not sure where to start. Anybody know where to get one from? They are exactly the same as the RRC, I know this as I have already done the passenger side with an used RRC part. Cheers. Rob. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 19, 2008 Share Posted February 19, 2008 20 - Front door glass run MWC9602 (both RH/LH doors) Google for the part# for a start to where you might get them from. If you need 14 or 15 it depends on the disco you have (year should be enough). Quote Link to comment Share on other sites More sharing options...
