petrolhead63 Posted February 19, 2008 Share Posted February 19, 2008 Hi, I have just got my TD5 discovery and it has a curious Alarm/locking issue. It all works fine except for first thing in the morning it will not "plip" and i have to insert the key, unlock/lock it again, then it plips fine all day until the next morning! Very odd........anybody had this and discovered what it is?? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 19, 2008 Share Posted February 19, 2008 Somewhere in the dim recesses of my mind I recall seeing something about the alarm receivers in these vehicles. If the alarm ECU or the receiver thingy (which I think is a separate little black box up in the headlining, though I haven't had many dealings with this) receives continuous interference over a long period which it interprets as an attempt to signal it, it shuts down to avoid flattening the vehicle battery - because every time it hears a signal it "wakes up" to listen to it. That could be what is happening - may be something to do with where you park it at night? I think the remedy was to fit a different type of receiver unit, but parking it in a different place might be just as effective. I'd guess your lock/unlock on the key probably resets the system and you park it in a different place during the day which doesn't have the interference, hence you don't have the problem during the day. The bad news is that you probably (can't remember) need a Testbook/IDS diagnostic system to set up the new receiver and test it properly. Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted February 21, 2008 Author Share Posted February 21, 2008 thanks for that, it is very curious. Funny thing is today it opened......and the temperature had lifted! Only had this one a week and it is the first warmer day. I shall change the plipper batteries too just in case, they can be odd things! Quote Link to comment Share on other sites More sharing options...
