BogMonster Posted November 27, 2005 Share Posted November 27, 2005 I went away for a bimble around the hills this afternoon & ended up with an unexpected challenge: found a deserted Merc, having "failed to proceed" quite seriously did a good job of it too - big 11.50 tractorgrip tyres, right out of sight: As I've said on occasions it can be a bit soft here, even if it often doesn't look like much in the photos No sign of the driver but I knew whose it was so thought I would try and shift it with the Milemarker - G-wagens are heavy bits of kit at the best of times, never mind when they're bogged out of sight on one side in a swamp! And nobody else around meant it was going to be a dead weight - should be a good test First attempt just ripped a load of ground up dragging the 90 forwards, second attempt I spun the front wheels in using reverse gear, which just made a bigger hole (90 still moved forwards) so I had to wind out more Dyneema and drop the front down over a bank: mid pull I got out for a look - you can see what sort of strain is on it by the suspension - with all the recovery kit in the back, the back normally sits slightly lower than the front, not at the moment though! must have been nearly on the bump stops I reckon Shifted it so far but then the bank also started to move but the Merc came out - just. I had to have both feet on the brake pedal to stop the front wheels turning (there was so much grip with all the weight on the nose that I couldn't keep the wheels locked with one foot) So the Milemarker might be slow but I regret to advise I still haven't found anything that will stall it in low range. Damn I love that winch B) Then the owner turned up with another guy in a 110 to pull it out - about 5 min too late having walked for an hour to get help Later on in the afternoon, bit of a scenery shot All in all a thoroughly enjoyable afternoon on the 3rd rock from the Antarctic Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2005 Share Posted November 27, 2005 (edited) Another Bogbuster success love the '3rd rock from the Antartic' sign off Edited November 27, 2005 by western Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 27, 2005 Share Posted November 27, 2005 Yep, that's impressive. And that scenery so reminds me of Dartmoor. Quote Link to comment Share on other sites More sharing options...
