Les Henson Posted February 21, 2008 Share Posted February 21, 2008 Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 21, 2008 Share Posted February 21, 2008 Yup, that's quite rusty Mo Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2008 Share Posted February 21, 2008 Wonder where this one comes? Obviously stopped sharply with a trailer as the drop plate & crossmember were trying to tuck under the back! The truck was for sale too, £900. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted February 21, 2008 Share Posted February 21, 2008 Les. What are you going to weld to??? New chassis time. Al. P.S. - John, when did you paint your 109 green??? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 21, 2008 Share Posted February 21, 2008 Well at least it makes mine look better....... Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2008 Share Posted February 21, 2008 Doubt there's any good steel remaining to weld too. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 21, 2008 Share Posted February 21, 2008 It's not V8Freak's is it? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 21, 2008 Author Share Posted February 21, 2008 No - his front one is like that Les. Quote Link to comment Share on other sites More sharing options...
Steve King Posted February 21, 2008 Share Posted February 21, 2008 Errrrm Les it's not mine is it??! I know it's on the way out but I was hoping it might just creep through the next MOT with a bit of underseal and a splash of mud here and there! Steve Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 21, 2008 Share Posted February 21, 2008 It's not that bad Les..... At least you had something to weld to unlike the pile of rust I see on the floor from the pictures above. I can't believe you got in that truck to go to the lakes! When you said it was fragile, I didn't think you meant eggshells !!! Neil (And Jamie, you ought to know better.... ) Quote Link to comment Share on other sites More sharing options...
Marc.be Posted February 21, 2008 Share Posted February 21, 2008 how about this one Quote Link to comment Share on other sites More sharing options...
CoolHands Posted February 21, 2008 Share Posted February 21, 2008 should've patched it up Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 21, 2008 Author Share Posted February 21, 2008 The rear silencer support is missing - it'll fail the MOT Les. Quote Link to comment Share on other sites More sharing options...
muddy Posted February 21, 2008 Share Posted February 21, 2008 the end fell off! Quote Link to comment Share on other sites More sharing options...
Orange Posted February 21, 2008 Share Posted February 21, 2008 Blimey!! Even my Range Rover one wasn't that bad!! Maybe I shouldn't have sold the RR and got a 90.......they look like rust buckets to me!! Quote Link to comment Share on other sites More sharing options...
JST Posted February 22, 2008 Share Posted February 22, 2008 Les - can you give us some pointers - which are the bad bits? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 22, 2008 Author Share Posted February 22, 2008 I bolted the replacement crossmember to the rear tub, welded some tabs on the top of the chassis rail to line it up, then cut out the rot in sections so as to keep everything nice and straight. There was good metal after the curve, so it's repairable at least. Not too bad considering what it was like. No tow bar brackets though - even they were rotten. Les. Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted February 22, 2008 Share Posted February 22, 2008 it wasnt too bad tbh, mine was worse before i got it replaced. i actually had no idea how bad mine was, because it had been filled with body filler many times by the previous owner. Quote Link to comment Share on other sites More sharing options...
disco tony Posted February 22, 2008 Share Posted February 22, 2008 nice job there Les. What thickness plate did you use?, mines due in the summer! will 1.2mm sheet work? Quote Link to comment Share on other sites More sharing options...
Jurriaan Posted February 22, 2008 Share Posted February 22, 2008 I remember a really bad one at a Ninety for sale at Sodbury last year... Didn't bring my camera though. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 22, 2008 Author Share Posted February 22, 2008 That's 2.5mm plate. Standard is 2.2mm I think. 1.2mm is waaaay too thin - not much thicker than body steel. One sharp tug and you'll be doing the job again Les. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 22, 2008 Share Posted February 22, 2008 will 1.2mm sheet work? Crikey, I used 2mm just to repair the floor in the range rover!! Quote Link to comment Share on other sites More sharing options...
