axle nose oil seal
JST
You need one of these then!
Gaoty: If your diff is noisy and the oil seal is leaking it could well be shot bearings, check for play up/down in the pinion. If your prop sliding joint has seized that can lock it to make it seem like there's less play, it also puts big thrust loads on the pinions. Dad did two diffs that way. :rolleyes:
