simonr Posted February 22, 2008 Share Posted February 22, 2008 I have an idea (nothing to do with LR's) which requires the use of a half shaft as a prop shaft. Do any of you know if series wheel drive flanges are the same spline as 10 spline half shafts - or if 24 spline flanges will fit on both ends of a 24 spline shaft? If so, that would be tremendously helpful! Cheers, Si Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 22, 2008 Share Posted February 22, 2008 The fact that 10-spline diffs are interchangeable suggests that the splines at the diff end are the same - I can't imagine they'd then use a different spline on the hub end, although later setups were 24-spline at the hub to correspond to the Salisbury axles 24-spline setup. Quote Link to comment Share on other sites More sharing options...
Gromit Posted February 23, 2008 Share Posted February 23, 2008 if 24 spline flanges will fit on both ends of a 24 spline shaft? They do fit on both ends - just been out and checked on the old ones I pulled out last week. Quote Link to comment Share on other sites More sharing options...
