pigfarmer Posted February 27, 2008 Share Posted February 27, 2008 The misses has just bought a 98 xei and it dont sound good . The fella sold it cheap and told her a wheel bearing needs doing (among other things). Having driven it the rear certainly sounds like a trashed bearing and its vibrating a bit as well. One rear wheel has play in it so i'm fairly happy with the diagnosis. Now i've had a look through the forum and seen the kind of horrors it could also be i'm wondering if it was cheap enough !!!!!! Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 27, 2008 Share Posted February 27, 2008 The misses has just bought a 98 xei and it dont sound good . The fella sold it cheap and told her a wheel bearing needs doing (among other things). Having driven it the rear certainly sounds like a trashed bearing and its vibrating a bit as well. One rear wheel has play in it so i'm fairly happy with the diagnosis. Now i've had a look through the forum and seen the kind of horrors it could also be i'm wondering if it was cheap enough !!!!!! does it sound as if there is a spitfire chasing you down the road if so yep its a wheel bearing Quote Link to comment Share on other sites More sharing options...
pigfarmer Posted February 28, 2008 Author Share Posted February 28, 2008 does it sound as if there is a spitfire chasing you down the road if so yep its a wheel bearing Sure does, just realised its drum rear as well so she will be pleased i dont change the discs at the same time. Looks as though Paddock are going to get another wedge of cash ! Quote Link to comment Share on other sites More sharing options...
Badger_1 Posted February 28, 2008 Share Posted February 28, 2008 The misses has just bought a 98 xei and it dont sound good . The fella sold it cheap and told her a wheel bearing needs doing (among other things). Having driven it the rear certainly sounds like a trashed bearing and its vibrating a bit as well. One rear wheel has play in it so i'm fairly happy with the diagnosis. Now i've had a look through the forum and seen the kind of horrors it could also be i'm wondering if it was cheap enough !!!!!! Ive just bought a 98 xei as well looks like we could be sharing notes good luck Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 28, 2008 Share Posted February 28, 2008 Sure does, just realised its drum rear as well so she will be pleased i dont change the discs at the same time. Looks as though Paddock are going to get another wedge of cash ! make sure you have a good torque wrench the stake nut on the end of the drive shaft has to be done up to 340nm if i remember correctly Quote Link to comment Share on other sites More sharing options...
