Froggy MOT
Jason2
How do chaps!
Bin wanting to do it for ages cos I'm wrecking the family Disco with toooo much off-roading so I've bought a project/toy
110 2250 petrol pick up, 1985, good all round condition, one of the front out riggers is rusted away, a few holes in the chassis, all the other out riggers & rear cross member have already been changed (at some time in the past!)
What I wana know is (as I have a set off the Disco) will 235/70/16 macho's tyres be OK for the time being as the originals are knacked and I have to get it through a French MOT, yeh I know but if it will pass a U.K one with those tyres it will give me an idea.
Your thoughts please on tyres & MOT.
Oh yeh and it's leaning to one side, weak spring? anyone got a quick fix, like popping a few washers in to level her up.
Cheers
Jason
My defender passed with brand new (read as 20+ mm of tread) 235/85/16 Insa Turbo Sahara's, exactly the same tread pattern as the Greenway Macho's. Provided you adjust the lock stops to stop 'em rubbing on full lock and they'll actually go under the arches then it'll pass a UK MOT.
Cheers,
Cheers Chaps
Got a reply from a local French 4x4 forum saying that I will have no problem putting the 235/70/16 mitchel syncros off the Disco for the C.T (MOT) on the 110.
Better than the TT's as they can give dodgy break test results.
Sorted.
All I've got to do is spend another day welding the chassis up
Thought I would let you know how the control tech (French mot) went!
Could'nt be bothered to swap the wheels over from the Disco, so I took it with "Greenway Machos" Failed on headlights (knew that already as they are the original English ones) and 2 track rod ends, Not bad eh for a car that's 23 years old & not been on the road for over 2 years.
