The_Menace Posted March 2, 2008 Share Posted March 2, 2008 I have just bought a series 3 88" for trialling (RTV) and have been advised to change the front rims from the standard SWB rims to improve the turning circle by having a smaller distance, inner side of nave plate to inner edge of rim. I have been advised the following: 1 ton rims - Perfect but expensive 8 spokes - better but offset varies modulars - same as 8 spokes LWB rims - i have had mixed reports. Can anyone shed any light on the difference between LWB and SWB rims as far as the offset goes, I will be fitting 750r16 tyres. Thanks Rob Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 2, 2008 Share Posted March 2, 2008 As far as I know - LWB rims have 1/2" more offset. Les. Quote Link to comment Share on other sites More sharing options...
The_Menace Posted March 2, 2008 Author Share Posted March 2, 2008 As far as I know - LWB rims have 1/2" more offset.Les. So is that 1/2" more on the outside , meaning 1/2" less on the inside as offset is usually measured from outside of nave plate to outer rim? Quote Link to comment Share on other sites More sharing options...
jimfoo Posted March 3, 2008 Share Posted March 3, 2008 So is that 1/2" more on the outside , meaning 1/2" less on the inside as offset is usually measured from outside of nave plate to outer rim? Land Rover Wheel Sizes Model Rim Diameter Width Offset Part Number 88 1959-1967 16" 5" 1" 231601PM 88 1967-1974 15" 6" 1" NLA 109 1959-1971 16" 5.5" 1.75" 272309 109, 90, 110 16" 5.5" 2" NRC7578PM 130, 110 USA 16" 6.5" 2.25" ANR1534PM Quote Link to comment Share on other sites More sharing options...
Spongie2a Posted March 3, 2008 Share Posted March 3, 2008 1 TON FC 16" 6.5" 2.25" - 3.25" Varying part nos Quote Link to comment Share on other sites More sharing options...
