les Posted March 3, 2008 Share Posted March 3, 2008 when traveling along at 50-80 i take my foot of the gas and get a clonk the same happens when i step on it again could it be uj,s its a 3.9 auto Quote Link to comment Share on other sites More sharing options...
SteveRK Posted March 3, 2008 Share Posted March 3, 2008 At that speed i would guess that its not wear in a UJ. I recently replaced the U/J in the rear prop at the axle end (it has massive ammounts of wear) and never had any clunks - What i did have was vibration at around 50-60. If you are getting a definate 'clunk' check out gearbox mounts as well as U/Js Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 3, 2008 Share Posted March 3, 2008 Check A Frame Ball joint Raduis arm bushes Rear Arm bushes to axle and to chassis mts Prop splines and UJs Engine / Gearbox Mtgs Other poss is the gearbox mainshaft, but try all the above 1st before panicking too much Use a BIG Prybar Nige Quote Link to comment Share on other sites More sharing options...
les Posted March 4, 2008 Author Share Posted March 4, 2008 will go through your list nige not panicking as have spare g/box Quote Link to comment Share on other sites More sharing options...
