the intermotor list of parts
callum
i think i suck at searching.
i'm looking for a list of leccy fan switches and need to find out the thread size and temperature range. i recall a list of intermotor switches appearing at some stage, but i cant find it in the tech archive or doing a search. on the off chance that someone actualy remembers switches, i need the switch to kick in at about 100degrees and drop off at 88-ish. thread size not too much of an issue yet.
you could always try; http://www.intermotor.co.uk/prod_cat.asp
online catalogue
have tried there alas it does not list the temperature range or the thread size, only the compatability. as this is not going into something OE i am unable to use that sort of cross referencing. once i have found the switch i am looking for, i shall be able to use that to find out where it came from.
I might get slated for this, but try popping into your local Halfrauds. I always used to have an Intermotor catalogue behind my parts counter. I'm almost probably 99% positive that the specs were in the back. Obviously, failing that, your local motor factors may have one- do you have a Partco or Autella nearby?
