Orgasmic Farmer Posted March 4, 2008 Share Posted March 4, 2008 Well finally got round to investigate the blowing exhaust on the Subaru yesterday. Found that the centre pipe had corroded 3/4 of the way around where attached to a stone-guard. Unfortunately I am clean out of bits of repair pipe and the MIG welder is down with no gas at the mo... Hmmm what to do. Found that roll cage tube had the same internal diameter so cut out a 3 inch section of rusty pipe and went for a butt weld using all I had for metal gluing purposes (Stick welder on 90 amps and 3.2 mm rods ). I thought I might as well have a go as I had nothing to lose. Bear in mind this is the original centre pipe so is now 15 years old! Well it worked perfectly. I just couldn't believe it. Kept the heat on the thicker stuff and it just ran in to the thin pipe and formed what looked to be a tidy weld (I really am no expert). Not a single hole was blown in it. Repeat on other side and all bolted back on and good now for another 15 years :P Sorry, as I say I was chuffed. Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 4, 2008 Share Posted March 4, 2008 Well finally got round to investigate the blowing exhaust on the Subaru yesterday. Found that the centre pipe had corroded 3/4 of the way around where attached to a stone-guard. Unfortunately I am clean out of bits of repair pipe and the MIG welder is down with no gas at the mo... Hmmm what to do. Found that roll cage tube had the same internal diameter so cut out a 3 inch section of rusty pipe and went for a butt weld using all I had for metal gluing purposes (Stick welder on 90 amps and 3.2 mm rods ). I thought I might as well have a go as I had nothing to lose. Bear in mind this is the original centre pipe so is now 15 years old! Well it worked perfectly. I just couldn't believe it. Kept the heat on the thicker stuff and it just ran in to the thin pipe and formed what looked to be a tidy weld (I really am no expert). Not a single hole was blown in it. Repeat on other side and all bolted back on and good now for another 15 years :P Sorry, as I say I was chuffed. Sortd then don't ya just love it when all goes to plan. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 4, 2008 Share Posted March 4, 2008 That bit of pipe will outlast the rest of the motor now Les. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted March 4, 2008 Share Posted March 4, 2008 Mark Another bit of kit, to load for May Just in case ,,, Well done Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 4, 2008 Share Posted March 4, 2008 Well done. You can tell when the rusty pipe gets too hot as it starts to fizz just before it retreats faster then you can keep up with the welder. I remember the days when I used to carry a couple of jubilee clips and a coke can for temporary exhaust pipe repairs. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 4, 2008 Author Share Posted March 4, 2008 Amazing what one can fix with coke cans. I remember back in sixth form one of my mates had a Fiesta Supersport but was moaning about its performance. I had a look and found that 2 of the HT leads were barely attached at the plug end and one had no physical contact at all!. I looked around and found a coke can in the gutter and used it to make new plug terminals which I pressed into the HT leads to make a tight fit. He took it for a drive and remarked it had never gone so well since he bought it! Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 4, 2008 Share Posted March 4, 2008 I used to turn coke cans into lanterns at parties. Using a Leatherman blade I would make long cuts in the side of the can from top to bottom about 10mm apart. Squash the can down a bit and insert a tea light. I would make them secretly and dot them around without anyone noticing. Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted March 5, 2008 Share Posted March 5, 2008 exhast repairs and mending engines with coke cans is cool, but making girly lanterns is just damn nerdy!! Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 5, 2008 Share Posted March 5, 2008 exhast repairs and mending engines with coke cans is cool,but making girly lanterns is just damn nerdy!! Opps! Wrong forum! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 8, 2008 Share Posted March 8, 2008 Lanterns out of coke cans at parties is cool, it gets my vote I'll go stand in the nerd corner with night train One time on a touring trip to France on our scooters, a member of our party holed the engine casing on his Vespa Rally 200 on a protruding lump of steel on the exit ramp of the ferry. He repaired it with Araldite and a McDonalds aluminium foil ashtray It lasted for the full 2 weeks holiday and got him home Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 8, 2008 Share Posted March 8, 2008 Lanterns out of coke cans at parties is cool, it gets my vote I'll go stand in the nerd corner with night train It shows imagination and creativity, some girlies like that. I usually stand in the corner with them, sometimes I whittle wooden pendents out of firewood for them while discussing cosmology too. Quote Link to comment Share on other sites More sharing options...
Shackleton Posted March 9, 2008 Share Posted March 9, 2008 Ah whittling in the dark and carbonated drinks cans, all the hall marks of the sexual predator Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 9, 2008 Share Posted March 9, 2008 Ah whittling in the dark and carbonated drinks cans, all the hall marks of the sexual predator 'tis harmless, cosmology makes a pretty good contraceptive. Quote Link to comment Share on other sites More sharing options...
