Old Laptop > GPS
Gremlin
Hi All, what do i need to do to turn an old laptop into a gps unit?? besides the gps reciever i know i need software, what software?? any freebees?? Maps??
Any information will be welcome as i am walking in dark and dont have a clue what i should look for or do.
Thanks Grem
I guess you are in Malta ?
do you have any good digital maps of the island .............. if yes, then what format are they (WGS84 etc)
I think in your case I would use oziexlplorer and either a scanned map or a digital map................there are full versions of ozi kicking around ;)
you can get a usb gps receiver (gps mouse) from ebay............ or alternatively use a bluetooth gps together with a bluetooth dongle on the laptop ....... http://www.maplin.co.uk/Module.aspx?Module...gps&doy=6m3
Ian
Oziexplorer will allow you to use scanned maps and calibrate them (but it's better to get the whole package from someone, with the image files + the calibration files, or else you'll go nuts trying to calibrate them all!). I doubt it will accept the same maps you already have in the Garmin.
For road travell, you have Autoroute (I guess they will have a map for Malta ;) ).
You didn't tell us if you would like onroad/street/routable nav (vector maps) or just a simple positioning solution with something more like Ozi offers (raster maps).
If you say you have the Malta garmin map, I believe you're after the 1st kind of sat nav.
To use a garmin map on your laptop you can get nRoute, it's free.
Your laptpop is a bit low on specs, at least the RAM could have been better. I think it should work though, not great but acceptable for a newbee.
