q-rover Posted March 7, 2008 Share Posted March 7, 2008 Finally got round to doing it last night. Not really much installation required as I had thought about it and planned ahead a bit. Previously I had always hardwired my CB's into the vehicles like the stereo. However due to a lack of a suitable place in the P38 I chose a slightly different approach. I purchased THIS CB, so doesn't have to permanantly be fitted. Another advantage is I can take it out of the car if guiding someone through a tricky section and have better communication. Also 'out of sight out of mind' when not in use. Fitting the mount for the arial, also took some thought. I eventually went for this one 'side mount', 2nd down. Fitting was straight forward and I fitted it on the rear plastic panel. This simply pulled off after removing the 3 screws. Behind this is a plastic plug that fills a hole through to the interior via the bodyshell structure. I replaced this with a similar sized rubber grommet. The antenna mount was wired up, but I had to add an extra earth wire to go through the same grommet and fix to a suitable point in the interior. Then all that was left was pulling the wire forward (approx 7.5m cable) to the centre console. I didn't quite get finished but will pull it through the ashtray after making a suitable hole. This means that I can keep the connector and about 10-15cm of cable out of site when not in use. The only drawbackis that the mount follows the angle of the sidepanel so the arial doesn't point straight up. I may trim the mount to adjust the angle later, to make it look a bit better when the antenna is installed. Some pictures. One thing I forgot to mention is the mounting points on the antennamount need to be trimmed slightly. Not too much, though. :roll: Wiring for the antenna with extra ground/ earth wire. Plastic cap replaced by rubber grommet where wiring goes through bodyshell. Antenna mount from the outside. Quote Link to comment Share on other sites More sharing options...
