twizzle Posted March 7, 2008 Share Posted March 7, 2008 can any body tell me how i rejister the 109 as the postoffice has no paperwork on getting the V5 changed into my name an changing it to a oil burner TWIZZLE Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 7, 2008 Share Posted March 7, 2008 Register it to you (V62 form if you've lost the V5) THEN write to the DVLA and tell them you've changed the engine. You might not want to tell them about any other bits as if you get the wrong flavour of muppet at the DVLA you could be staring down an SVA test It's also important to use terms like "direct replacement" "land rover genuine" "newer equivalent" etc. rather than "swap" "modified" "upgrade" etc. when talking about the engine change as they pick up on certain words. Quote Link to comment Share on other sites More sharing options...
twizzle Posted March 9, 2008 Author Share Posted March 9, 2008 Register it to you (V62 form if you've lost the V5) THEN write to the DVLA and tell them you've changed the engine.You might not want to tell them about any other bits as if you get the wrong flavour of muppet at the DVLA you could be staring down an SVA test It's also important to use terms like "direct replacement" "land rover genuine" "newer equivalent" etc. rather than "swap" "modified" "upgrade" etc. when talking about the engine change as they pick up on certain words. it's an old v5 and it's in my dad's name TWIZZLE Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted March 9, 2008 Share Posted March 9, 2008 Just a heads up - the DVLA may want some proof of the engine swap. See here Quote Link to comment Share on other sites More sharing options...
