ciderman Posted March 8, 2008 Share Posted March 8, 2008 Anyone know the size of the thread on the nut that holds the 5mm nylon pipe to the union ? its about 3/8 but not a BSPP thread Im guessing its NPT but need to know for sure . Quote Link to comment Share on other sites More sharing options...
white90 Posted March 8, 2008 Share Posted March 8, 2008 Jase I looked in the Install instructions and couldn't find the spec but found this if any use? http://www.devon4x4.com/component/option,c...showcaticons,no Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 8, 2008 Author Share Posted March 8, 2008 Thanks Tony , That may be a last resort , What I want to do is use a pushfit union in place of the nut and ferrule , Then some nice flexible Polyurethane 5 mm pipe . Quote Link to comment Share on other sites More sharing options...
white90 Posted March 8, 2008 Share Posted March 8, 2008 D44 use the stronger kit they sell with the right angled connection http://www.devon4x4.com/component/option,c...showcaticons,no http://www.devon4x4.com/components/com_pho...a55e4a54103.jpg Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 8, 2008 Author Share Posted March 8, 2008 That kits ok But , looking at it , A nice strong hose that wont stretch , and the weak point is ?? The small brass union , If summat catches the hose , it aint gonna give , but the union will leaving you snookered . Quote Link to comment Share on other sites More sharing options...
white90 Posted March 8, 2008 Share Posted March 8, 2008 possibly have you lost an ARB connection then? I know Tim did Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 8, 2008 Author Share Posted March 8, 2008 Yeah ! The rear one , The Nylon pipe snapped off at the ferrule , Thats why im changing from nylon to Polyurethane , It streches before it snaps . Its also more resistant to kinking and has a better memory than nylon Quote Link to comment Share on other sites More sharing options...
white90 Posted March 8, 2008 Share Posted March 8, 2008 Sounds a good idea. Quote Link to comment Share on other sites More sharing options...
red90 driver Posted March 8, 2008 Share Posted March 8, 2008 Just run an 1/8 BSP tap down the brass fitting. It's a very close fit, then obtain an 1/8 BSP - 6mm air fitting, use some quality air tube (I used FESTO PUN-H) and then connect to an 1/8 BSP fitting on the compressor solenoid. 6mm tube and fittings are SO much easier to aquire than poxy 5mm stuff. I have also not used the ARB solenoids and have instead used FESTO 12VDC items - Helluva lot cheaper than the ARB ones!! Oh - you will also need the later style of brass fitting on the diff housing - the type that only uses an o-ring in compression. Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 8, 2008 Author Share Posted March 8, 2008 my local pneumatics supplier sells the solenoids IIRC about £17 each . I have the later O ring unions but I would like to make up some steel ones . Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 9, 2008 Share Posted March 9, 2008 1/8"BSP & 1/8"NPT are almost identical in diameter but BSP is 28tpi and NPT is 27tpi. Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 9, 2008 Author Share Posted March 9, 2008 Nice one Phil , I will do what Red90 sugested , Run a 3/8 BSP die down over it . Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 9, 2008 Share Posted March 9, 2008 I had thought about doing something similar but realised that 5mm fittings are special order where I am. And to go to 6mm would be a pain in the neck. Would then have to get a 5-6mm connector to go into the solonoid or change it. Either way the cost goes up. Will try and see if the pneumatics place I use do a 5mm push fit to go over the bulkhead fitting on the diff. I didn't realise there were 2 versions. I assumed they were all the same. A small ferrule that sits inside the pipe with an olive over the pipe and then a nut to to hold it all down with. So whats the other way. Mine is like the fitting kit that Tony linked to. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted March 9, 2008 Share Posted March 9, 2008 possiblyhave you lost an ARB connection then? I know Tim did Ahh that reminds me, best have a look, Being honest, bar for a pressure wash, the truck had not been touched yet !! Thanks Tony Quote Link to comment Share on other sites More sharing options...
