mmgemini Posted March 9, 2008 Share Posted March 9, 2008 I'm short on alli sheet at present. I'm making a mounting so it going to, have to, be checker plate. I've got a few off cuts about that will do. I'm not happy about screw/bolting things to the bar side of the checker plate, which I'm going to have to. So Tips for what I can place between the checker and the mount. Or Is there an easy way of removing, neatly, some of the bars on the checker plate. Thanks mike Try was Lord Mayor of London. Can't died in the workhouse. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted March 9, 2008 Share Posted March 9, 2008 Would it be possible to make a washer out of a piece of chequerplate so that when placed face to face the bars miss each other? ie the bars on the washer will sit on the face of the plate and vice versa. You could remove the bars with a Dremel &c or even use a sharp chisel as a scraper. Quote Link to comment Share on other sites More sharing options...
Paul Humphries Posted March 9, 2008 Share Posted March 9, 2008 You can get special drill bits that do such a job. Unfortunatley I cann't think fo their name at present nor can find a link Basically they are used to drill a second hole when you want to have an allen screw etc below the surface in thick materials. You drill the first hole for the bolt etc and then the special drill has a plain section that located in the hole so it then only drills the second, larger dia. Probably a little OTT for what you need. Personally I'd look at cheap and cheerful flat wood drill bits. If slow enough speed then they should chip the ridges off the chequerplate around the mounting hole area. You might need to regrind the wood bit to give flat areas but is a good starting point for making your own tool. Paul Humphries Quote Link to comment Share on other sites More sharing options...
rtbarton Posted March 9, 2008 Share Posted March 9, 2008 Counterbore Quote Link to comment Share on other sites More sharing options...
muzaz Posted March 9, 2008 Share Posted March 9, 2008 You can get special drill bits that do such a job.Unfortunatley I cann't think fo their name at present nor can find a link Basically they are used to drill a second hole when you want to have an allen screw etc below the surface in thick materials. You drill the first hole for the bolt etc and then the special drill has a plain section that located in the hole so it then only drills the second, larger dia. Probably a little OTT for what you need. Personally I'd look at cheap and cheerful flat wood drill bits. If slow enough speed then they should chip the ridges off the chequerplate around the mounting hole area. You might need to regrind the wood bit to give flat areas but is a good starting point for making your own tool. Paul Humphries you'll need a spot facing bit to do that, we use them at work for sheetmetal work...but I dont know where you'd buy them from Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 9, 2008 Author Share Posted March 9, 2008 Right you two. Thanks. You help me suss it. I do have a cheap bench drill. Also I have some of those little rubber bounting pads for small sanding discs. So. Disc thing in drill. Plate under dasc. That shouild kill the job. All I needed was a push in the right direction How's Roger. Long time no talk. mike Try was Lord Mayor of London. Can't died in the workhouse. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 9, 2008 Share Posted March 9, 2008 Spot face cutter or peg drill. Quote Link to comment Share on other sites More sharing options...
hattymender Posted March 9, 2008 Share Posted March 9, 2008 You might wince a bit at this but I've found that most checker plate is as soft as sh#t and can be worked with woodworking tools, bandsaws etc. (Doesn't seem to be too bad on blade life). I had a similar problem. Set about a bit of plate with an old Black and Decker power plane. Came off clean as a whistle. For true excitement you can shape with a router, but the swarf gets everywhere (and knackers the pump in your washing machine if you don't get it out of your clothes). Rich Quote Link to comment Share on other sites More sharing options...
