Tris Cocks Posted March 9, 2008 Share Posted March 9, 2008 Ive realised ive got lot of free play in my steering, I can turn the steering wheel about a tenth of a turn before the wheels start to move. The problem is that im not sure what I can do to stop this. Any ideas and recommendations would be much appreciated. Tris Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 9, 2008 Share Posted March 9, 2008 First thing to check i the nut on the steering drop arm. If that is loose it'll produce a lot of slack in the system. After that I'd look at the UJ's on the column. Quote Link to comment Share on other sites More sharing options...
nige90 Posted March 9, 2008 Share Posted March 9, 2008 Only a 10th you lucky chap ! Not an unusual problem with this type of steering. There is adjustment, look for a stud and locknut on top plate of the steering box. Careful as you can end up with the steering going very tight towards full lock. But as Walfy says, check all joints first. The MOT allows 75mm of freeplay. MOT Guide Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted March 9, 2008 Author Share Posted March 9, 2008 Thanks for the advice guys. i would go out and have a look tomorrow but with the weather thats forcast i think i will wait. Quote Link to comment Share on other sites More sharing options...
newclear Posted March 10, 2008 Share Posted March 10, 2008 Also have a look at the Panhard Rod bushes, it ties the Chassis to the Axle in a diagonal direction, in front of the front axle. It's got a slight kink in one end so it misses the Diff pan. Best to get a helper if you can, and while they rock the steering have a look at the bush ends, if they move a lot could be worth getting those replaced. Another good place to check is the Ball joints on the front Tie bar, 2 ball joints, one on the end of the Drop Arm and one behind the Passenger side wheel. PM me if you need pictures as to what I mean, bit hard to explain in text. Cheers Matt Quote Link to comment Share on other sites More sharing options...
