Spark plugs for a 3.5 V8??
Landy 90 Hybrid
Afternoon all, I have just bought some new plugs for the beast, NGK BP6ES's but I have just read on the technical archive section (the topic with the PDF 3.5 V8 Flapper system Diagnostic Manuals) that it says NGK BP6RES? Which should they be? I take it the R means resistor type?
Kind regards
Jonathan
basically yes, the R is for resistor. the ones you have bought should be fine....
just as a point of interest, NGK now do some specifically designed for LPG installations, BPR6EIX-LPG, the only downside is the cost - approx £10 per plug plus VAT!!!!
