fatbloke Posted March 17, 2008 Share Posted March 17, 2008 Well I had a great day. Bitching for Mr Whibly for the first time in my first challenge, and with a good result. Not really knowing what to expect it was a bit of an eye opener, but I can only describe it as an awesome experience. Bring on the next one, hoping it won't be so cold and wet, now that the family jewels have decended to their rightful place. Quote Link to comment Share on other sites More sharing options...
simonr Posted March 17, 2008 Share Posted March 17, 2008 A few photos..... Quote Link to comment Share on other sites More sharing options...
simonr Posted March 17, 2008 Share Posted March 17, 2008 Quote Link to comment Share on other sites More sharing options...
steve b Posted March 17, 2008 Share Posted March 17, 2008 A few photos..... Looks like everyone had a good event, NAJW and the crew(s) must have worked hard to put this together. ......a couple of winch Q's...what are these winchs? ^^..are they Garwoods? How much line is on there? What is the line pull on the bottom and the top? Any problems with the line 'cutting into' loose layers underneath with what appears to be a LOT of rope? Finally is this what you have on the front of your 90 Nige (HFH)? Must find time to come along to one or two of these, looks like a great day out Cheers Steveb edited to say d'oh the pics are'nt there ......it's the one in SimonR's first lot of photo's 4 down and acouple up from the bottom......looks like front and rear of the same vehicle.... Quote Link to comment Share on other sites More sharing options...
tobes Posted March 17, 2008 Share Posted March 17, 2008 I was just reading about those winches today! here! Quote Link to comment Share on other sites More sharing options...
steve b Posted March 17, 2008 Share Posted March 17, 2008 Thanks for that link Tobes, ......more lovely engineering and system design, people have been busy in the last few months, great to see innovation in action. So Nige, what is your front winch 'thingy' then? Cheers Steveb Quote Link to comment Share on other sites More sharing options...
D9OSV Posted March 17, 2008 Share Posted March 17, 2008 Looks like an amazing event....... I unfortunately was unable to attend (Prepping vehicle for the Ultimate challenge next weekend) But i would like to say a BIG well done to everyone, but in particular.............. Chris Abel First overall+class win Adrian Turner Second overall+class win Ben Hollis Third overall All using Gigglepin Twin Motor winches Congratulations Jim Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 17, 2008 Author Share Posted March 17, 2008 I'll dig up the specs but its a Uprated Industrial Recovery winch, rated at around 14500 pull @ 2500 PSI and around 60 LPM max flow, has the OCV Bolted to the motor directly -running through a Superwinch H14 PTO and Pump and modified H14 Tank, the rear (now broken ) Milemarker is faster (around 60 ft Min max) and run off the same system with a second control valve, you can, and we did until the rear went bang yesterday- operate both at the same time, which can be fun, get it wrong and I could have a 130 LR Both I have modded to have air operated freespool which is a godsend from on off switches from within the cab, the front has around 100 ft 12mm plasma the rear 110 ft 11mm plasma every pipe is double braided 1/2 BSP the main feed bigger at 1.1/4in BSP The only prob is drive assist doesn't really work, but the pull of both is quite something..... I would normally say you can work them all day without a prob, but yesterday sort of p*ssed on that firework early on , and we had to use the front from then on for everything. Oh and the front winch is "VFH" (VeryFurKin Heavy) too Nige Quote Link to comment Share on other sites More sharing options...
najw Posted March 17, 2008 Share Posted March 17, 2008 I have re-posted the event results as unfortunately I made an admin error in the results and hence the prizegiving. The correct placings for Class 3 are as follows: 1st Graham Fuller - 1250 points =2nd Paul Bass - 1200 points =2nd Gavin Lawrence - 1200 points 4th Sue Gawne - 1000 points Apologies to Graham for the error which meant that he missed out on his moment of glory at the prizegiving after two years of trying. And commiserations to Sue Gawne whose disbelief at getting 3rd place proved to be well founded Quote Link to comment Share on other sites More sharing options...
steve b Posted March 17, 2008 Share Posted March 17, 2008 Thanks for the reply Nige, It looked kinda chunky wedged in the front of your 90 , is the drive motor the std for that winch? .....better not keep you too long, you've got a winch to apply some HFH unbrako engineering to. If you need any measurements I have a MM in bits in the shed atm. Cheers Steveb Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 17, 2008 Author Share Posted March 17, 2008 It comes with 3x options of drive motor, this one is the biggest. The Superwinch PTO is one of the biggest, but I could get a bigger one if / when funds allow and speed up the front winch, it might tho make the rear MM a tad too speedy ? Nige Quote Link to comment Share on other sites More sharing options...
alan kemp Posted March 17, 2008 Share Posted March 17, 2008 Well done Chris and Simon, superb drive to be so far clear of every one else. Well done Saley and Carl. I tried phoning John for ages on the way home, he must have been telling the world of his trophy as he was engaged constantly. We broke the rear winch rope twice before even getting a punch and had to swap fairleads, then bust yet another CV, reversing on full lock is not recommended even on Volvo portals. Then to put us out completely, the pan hard rod came together with a steering ram hose and we lost steering. Great site, well organised and well thought out as usual. I think the time limit on the winch ss was a little low as almost everyone who did it scored a lot less than most people who did the other ss. My apologies to the lady marshall on the trial ss as I got a little irrate when I "missed my slot". You guys do a great job and it is really much appreciated. Alan Quote Link to comment Share on other sites More sharing options...
gaf lad Posted March 18, 2008 Share Posted March 18, 2008 was it this section chris http://uk.youtube.com/watch?v=rqP9D7QysVY hope the link works not to good at this Quote Link to comment Share on other sites More sharing options...
gaf lad Posted March 18, 2008 Share Posted March 18, 2008 wasnt portal petes motor something else on special stage 2. wot a diffrence rear wheelsteer makes. video to follow just waiting for u tube to get its act together. kev Quote Link to comment Share on other sites More sharing options...
Mr Nick Posted March 18, 2008 Share Posted March 18, 2008 Nice , most excellant footage there. Nothing like a bit of good old - Cold, Dirty, Smelly British Water. And Well done to the both of you. Least you can look back and giggle about it now. Quote Link to comment Share on other sites More sharing options...
gaf lad Posted March 18, 2008 Share Posted March 18, 2008 ss 2 portal pete http://uk.youtube.com/watch?v=WdnWL3FC99Q when the others have uploaded i will put a link on here. cheer kev Quote Link to comment Share on other sites More sharing options...
JST Posted March 18, 2008 Share Posted March 18, 2008 a great truck, very capable and looked the dogs dangly bits, even awesome, but wheres the tree clip you cant show half a story! certainly made it easier for us following without it there! If he hadnt had the tree issue he would have won that stage hands down in my opinion. Quote Link to comment Share on other sites More sharing options...
Chris Abel Posted March 18, 2008 Share Posted March 18, 2008 was it this section chris http://uk.youtube.com/watch?v=rqP9D7QysVY hope the link works not to good at this Thats it! I did not want to run the risk of rolling the truck in the water, we abandoned that punch and went and found a few more easier ones. Rob Tunner's truck was going well on that special considering it was his first time out getting used to the truck, i think with a bit more time behind the wheel he will be hard to beat with the 4 wheel steer on the tight specials. Quote Link to comment Share on other sites More sharing options...
matt_f Posted March 18, 2008 Share Posted March 18, 2008 here's a link to my pics: howlin wolf round 1 Quote Link to comment Share on other sites More sharing options...
najw Posted March 18, 2008 Share Posted March 18, 2008 ss 2 portal pete http://uk.youtube.com/watch?v=WdnWL3FC99Q when the others have uploaded i will put a link on here.cheer kev I'm glad someone got that on video, hope someone got the second half although it was pretty heartbreaking to see him battling with that tree after he'd got through 7 gates in just over 2 minutes. Like James said he would have absolutely creamed the section if it wasn't for the tree. Quote Link to comment Share on other sites More sharing options...
gaf lad Posted March 18, 2008 Share Posted March 18, 2008 here's portal pete part 2 http://uk.youtube.com/watch?v=gLbgKD1iXlo just had to rack the ashe's and put a bit more coal in the pc. Quote Link to comment Share on other sites More sharing options...
tombraider110 Posted March 18, 2008 Share Posted March 18, 2008 I have only found one photo of me, and that that was when i was being dragged out of SS2 with a blown CV Quote Link to comment Share on other sites More sharing options...
