Waffles
Marc
is it possible to cut waffles or will it affect their strength :unsure:
thanks Marc
Guess it depends where you cut them? Many trim a few inches off one end to make them easier to fit in the rear tub and that won't do any harm.
  • 3 weeks later...
  • 2 months later...
thanks Marc
Yes, most things can be cut with the correct blade.
Second part - depends where you cut them.
say if you cut them so they are half the tickness or cut squares out of the the grid, then surely you can see they will be weaker?
whereas if you cut them half in length, they will be able to support more weight or deflect less for the same weight; obvioulsy taking that to extreme by making them 1 ft long makes them very strong indeed but FA use for bridging a ditch.
not sure what the point of this question is. :huh:
