Guest diesel_jim Posted December 3, 2005 Share Posted December 3, 2005 I've got a Td5 110, with the stupid "screw on" type fuel filler. my other rovers (90 and 110's) have/have had the metal type filler with the extendable jerrycan filler. Question is: can the earlier type filler be swapped in place of the Td5 one so i can fill fron jerrys again (without having to use the jerrycan extendable filler hose) I suspect the pipes look similar size, but would there be any issue with vacuum? (are the Td5 totally sealed or vented?). i'd have to drill 4 holes through the filler area to bolt it in, no big deal. cheers Jamie Quote Link to comment Share on other sites More sharing options...
western Posted December 3, 2005 Share Posted December 3, 2005 The only part that might stop you converting to the earlier filler neck/cap, is the hose from the filler neck to the tank Quote Link to comment Share on other sites More sharing options...
