orange rover Posted March 24, 2008 Share Posted March 24, 2008 just about to fit the td5 into the 90 just some more questions, will the 200tdi temp gauge work with the td5? i presume not but you never know Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2008 Share Posted March 24, 2008 td5 temp gauge will work with the 200Tdi & 300Tdi sender for fitting a td5 into a earlier vehicle more here Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted March 24, 2008 Share Posted March 24, 2008 Also, speak to Adrian Turner. He has fitted a TD5 into his 200tdi challenge truck. A helpful guy who knows what he is talking about. Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted March 24, 2008 Share Posted March 24, 2008 for fitting a td5 into a earlier vehicle more here interesting..... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 24, 2008 Share Posted March 24, 2008 td5 temp gauge will work with the 200Tdi & 300Tdi sender for fitting a td5 into a earlier vehicle more here That's odd Ralph, I had to put 55ohms of resistance into the wire from the green 300 sender (which is used in ROW build) to the TD5 temp gauge to get it to work properly, did you manage to wire yours up directly with no problem ? What did you do and what parts did you use ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2008 Share Posted March 24, 2008 That's odd Ralph, I had to put 55ohms of resistance into the wire from the green 300 sender (which is used in ROW build) to the TD5 temp gauge to get it to work properly, did you manage to wire yours up directly with no problem ? What did you do and what parts did you use ?Mo Still haven't fitted mine yet, got a bigger problem to sort out now [transfer box in Defender forum] I forgot you'd used some resistors on yours, maybe it's not as easy as I thought. Quote Link to comment Share on other sites More sharing options...
orange rover Posted March 28, 2008 Author Share Posted March 28, 2008 thanks for the answers, managed to get hold of a td5 gauge, will use that. think that showing correct water temp is somewhat important, so thought that would be the best solution. cheers spec Quote Link to comment Share on other sites More sharing options...
