JST Posted December 6, 2005 Share Posted December 6, 2005 Ralph, Hows the GKN going with the 255/85s fitted? apart from reduced rpm and road noise has your economy changed much? do you use it as a splitter gear or just a 6th gear? Will it pull it on main roads at 50mph say? just curious to compare. Quote Link to comment Share on other sites More sharing options...
western Posted December 6, 2005 Share Posted December 6, 2005 Working fine after a settling in fault, had to change the soleniod as it was sticking, I use the o/d as a splitter & 6th gear, it pulls well in 4th & 5th od, I have to change down on long/steep hills, not done much fuel comparisons yet, but seems to be using less, 110 is a fair bit quieter and nicer to drive. Quote Link to comment Share on other sites More sharing options...
