Mean Green Posted December 8, 2005 Share Posted December 8, 2005 I am treating "Mean Green" to a bit of a spruce up, at the moment the engine is out to let me replace the clutch. Since the clutch is out I have been able to have a poke around the bulkhead and it showing signs of rust - not too bad at the moment, but feels spongy in place. So I am thinking, since the engine is already out now would be a good time to replace the bulkhead. So, simple question - where is the best place to buy a new bulkhead? While I am on the subject, i will probably change the doors too - any suggestions on suppliers of these? (other than the usual Cr(P)addocks suspects) Quote Link to comment Share on other sites More sharing options...
McS Posted December 8, 2005 Share Posted December 8, 2005 I would have thought Landrover Heaven would have something in stock and not too far down the road from you either... HTH, Ross Quote Link to comment Share on other sites More sharing options...
the real muddy90 Posted December 11, 2005 Share Posted December 11, 2005 There's usually one or two on Ebay. Quote Link to comment Share on other sites More sharing options...
Dunc Posted December 13, 2005 Share Posted December 13, 2005 I would have thought Landrover Heaven would have something in stock Thouroughly recommend LR Heaven. Superb service. Dunc Quote Link to comment Share on other sites More sharing options...
Millsy Posted December 21, 2005 Share Posted December 21, 2005 If you are changing the doors - why not go for split ones? With the anti-burst locks they are just as (in)secure as the push-buttons, you get a lot more room inside and with the door tops off the visibility off road is superb. It's also a lot cheaper if you look at the prices rot-free push button doors go for - even allowing for a pair of alloy door tops be it the slash cut ones or the truly lovely Rocky Mountain ones. Quote Link to comment Share on other sites More sharing options...
Ant Posted December 21, 2005 Share Posted December 21, 2005 If you are changing the doors - why not go for split ones? That exactly what I've done on my defender. Picked up two series 3 door bottoms for £5 each and some snazzy ally door tops (military types with two moving windows) for £120 (complete & spotless). As Millsy said, lots more room inside, cheap and easy to replace if bent/broken/rotten and they look better IMO. Quote Link to comment Share on other sites More sharing options...
