windnwaves Posted April 4, 2008 Share Posted April 4, 2008 Hi Thanks for taking the time to read this... Just bought a V plate Freelander 5 door in need of a o/s door mirror glass.. I understand that you can or should be able swap the normal fixed version mirror assembly for a folding version I would rather do that if poss.. The local official dealers say they haven't done this swap as they replace like for like and don't know if it will work as they were only fitted to later models... Has anyone reading this question actually swapped the fixed mirrors for folding on a earlier model i.e around 1999/2000. If so did it need any major mods or just a little tweek here and there. No probs with some minor "Bodging" if required but I don't want to order the mirror without knowing if it will fit as its around £98 inc vat (Ouch!) Any help appreciated as I don't want to buy a replacement mirror glass for the current mirror assembly at around £20 if a full unit will go on. Comments and help much appreciated. Phil Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted April 5, 2008 Share Posted April 5, 2008 Fairly common mod amongst the Freelander Club fraternity. Only thing that needs to be done is to open out one of the mounting holes slightly. You can even go the whole hog and fit the electric ones too! Quote Link to comment Share on other sites More sharing options...
windnwaves Posted April 6, 2008 Author Share Posted April 6, 2008 Fairly common mod amongst the Freelander Club fraternity.Only thing that needs to be done is to open out one of the mounting holes slightly. You can even go the whole hog and fit the electric ones too! Just to be able to fold them in would be good... I assume that by electric ones, you mean some that fold when you turn ignition off ?. I didn't know that they did them or are they just a option on the FL 2 ? I guess they must use some addition wiring not in the standard harness. Any comments appreciated as whilst I don't want to get carried away with spending on the Freelander I do want to only do things once !! Cheers Phil Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted April 6, 2008 Share Posted April 6, 2008 I understand there were some electric folding ones, but most people just buy the later hand folding ones and fit those. Someone said that the folding ones are now cheaper and easier to get than the non folding ones! Quote Link to comment Share on other sites More sharing options...
viorelluta Posted April 7, 2008 Share Posted April 7, 2008 Just to be able to fold them in would be good... I assume that by electric ones, you mean some that fold when you turn ignition off ?. I didn't know that they did them or are they just a option on the FL 2 ? I guess they must use some addition wiring not in the standard harness.Any comments appreciated as whilst I don't want to get carried away with spending on the Freelander I do want to only do things once !! Cheers Phil electric mirrors at FL I = you can adjust mirrors' position using electric controls, plus they're heated (by the way, it's the only car I know with the mirrors heated all the time... strange) Quote Link to comment Share on other sites More sharing options...
windnwaves Posted April 7, 2008 Author Share Posted April 7, 2008 electric mirrors at FL I = you can adjust mirrors' position using electric controls, plus they're heated (by the way, it's the only car I know with the mirrors heated all the time... strange) Just as a matter of interest, were there any very basic mirrors fitted to the Freelander i.e manual mirror glass positioning and no heating element ? The ones on mine are electric adjustment for mirror angle etc, heated ( I saw the connections when the back FELL OFF ! ) but not able to fold in... I just wondered how many variations there are.... All I need is electric adjustment, heated but fully foldable.. Thanks Phil Quote Link to comment Share on other sites More sharing options...
Blippie Posted April 11, 2008 Share Posted April 11, 2008 There are three variations, and the fitting instructions are the same (I've posted those in your other thread) Originally they were non folding with electrical adjustment and heating. On the 2001MY (i.e. 2000 and onwards) the standard mirrors are folding, and have electric adjustment and heating. The ES & HSE models (i.e. top spec) have powerfold mirrors. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
windnwaves Posted April 11, 2008 Author Share Posted April 11, 2008 There are three variations, and the fitting instructions are the same (I've posted those in your other thread)Originally they were non folding with electrical adjustment and heating. On the 2001MY (i.e. 2000 and onwards) the standard mirrors are folding, and have electric adjustment and heating. The ES & HSE models (i.e. top spec) have powerfold mirrors. Cheers Blippie Cheers Blippie I'll try to reduce abit of forum traffic by posting any mirror info etc on my original newbie help request.. powerfold would be nice but I'm sure I can just about manage to fold them by hand Phil Quote Link to comment Share on other sites More sharing options...
Blippie Posted April 16, 2008 Share Posted April 16, 2008 It's tough, but then so is life. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
Princessjane Posted April 29, 2016 Share Posted April 29, 2016 Hi I am trying to find the post blippie refers to posting on this gentleman's previous post about fitting folding wing mirrors. My freelander has the fixed ones and is the 99 model thanks for any assistance Quote Link to comment Share on other sites More sharing options...
Glenlivet Posted April 30, 2016 Share Posted April 30, 2016 My 02 TD4 ES has electronic folding mirrors but, as far as I can tell, no heating. Unless that's another electrical bit that's failed.... Quote Link to comment Share on other sites More sharing options...
Nodge68 Posted May 14, 2016 Share Posted May 14, 2016 All Freelander 1 mirrors are headed, except for some early basic spec versions. Power fold mirrors are heated but can suffer bad connections at the heating element. Quote Link to comment Share on other sites More sharing options...
