kpodmore Posted April 8, 2008 Share Posted April 8, 2008 I cant remember which pipe to installt the x fan controller on, or does it matter. I cant find the instructions Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 8, 2008 Share Posted April 8, 2008 Hi,, if talking about the X-Fan Fitting Instructions Si says the bottom hose, even though i have seen loads in the top !! seam fine !! Quote Link to comment Share on other sites More sharing options...
JST Posted April 8, 2008 Share Posted April 8, 2008 this was asked a while ago and there are pros and cons for each i go for the top hose as that is the temp of the water leaving the engine if its too hot the fan will cool it rather than it being too hot then going into the engine. i see both sides of the arguments for top or bottom in the end top is easier to reach and you dont loose all the coolant doing it! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 8, 2008 Share Posted April 8, 2008 Bottom. You only want the fan to come on if the radiator's not doing it's job adequately. There's no point turning the fan on if the radiator could have cooled the water just fine all by itself. That said, it'll still work in the top hose. Quote Link to comment Share on other sites More sharing options...
kpodmore Posted April 9, 2008 Author Share Posted April 9, 2008 many thanks for the replies Quote Link to comment Share on other sites More sharing options...
