Marco Posted April 15, 2008 Share Posted April 15, 2008 Hi, consider to get a basic workshop press as they are relatively cheap. Main question, what size workshop press needed to press rubber bushes out of the suspension & steering parts? 6000kg, 10000kg, 12000kg or more? Cheers Marco Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 15, 2008 Share Posted April 15, 2008 Machinemart sell a 10-ton hydraulic bench press, which should be sufficient to do the bushes (I plan to get one this year). Next size up is a floor standing 15-ton press. I used to use a Record engineers vice to replace bushes until it snapped! Les. Quote Link to comment Share on other sites More sharing options...
Marco Posted April 15, 2008 Author Share Posted April 15, 2008 Thanks! So 10-12 Ton will be the size to go for. Marco Quote Link to comment Share on other sites More sharing options...
white90 Posted April 15, 2008 Share Posted April 15, 2008 Biggest you can afford/fit in that way it have more uses long term Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 15, 2008 Share Posted April 15, 2008 What Tony said - I've seen a 140ton press maxed out trying to remove some bushes, others just pop out easily. Quote Link to comment Share on other sites More sharing options...
Gunny Grunwald Posted April 15, 2008 Share Posted April 15, 2008 Hi, consider to get a basic workshop press as they are relatively cheap. Main question, what size workshop press needed to press rubber bushes out of the suspension & steering parts? 6000kg, 10000kg, 12000kg or more?Cheers Marco Hi Marco, Whenever I've had to change bushes I've used a bench vice (4" Jaws) and a couple of suitably sized sockets. Works perfectly and doesn't cost a bean! Cheers, Gunny. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 15, 2008 Share Posted April 15, 2008 I like Les have bust x2 big vices doing that luckily they are under guarantee Quote Link to comment Share on other sites More sharing options...
Marco Posted April 15, 2008 Author Share Posted April 15, 2008 Thanks for all contributions! Cheers Marco Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 15, 2008 Share Posted April 15, 2008 I think the record at work is a bit over 40 tons to pop a bush out, depends on which bush, how long it has been in there, whether it was fitted with a smear of grease when pressed in and consequently how much corrosion is holding it in place! 5-10 tons is pretty normal to move them so a 10 ton press will do "most" jobs - a good set of tools to fit into the bushes properly is more important IMHO Quote Link to comment Share on other sites More sharing options...
landmannnn Posted April 15, 2008 Share Posted April 15, 2008 Machinemart sell a 10-ton hydraulic bench press, which should be sufficient to do the bushes (I plan to get one this year).Next size up is a floor standing 15-ton press. I used to use a Record engineers vice to replace bushes until it snapped! Les. On evilbay there are a couple of shops who come in far cheaper than machine mart. Obviously not professional quality, but neither are machine mart Quote Link to comment Share on other sites More sharing options...
stobbie Posted April 28, 2008 Share Posted April 28, 2008 HI Marco, I use a 12 tons version. very cheap at www.soer.nl, I think around 80 euro's? Everything OK in Hengelo? Quote Link to comment Share on other sites More sharing options...
101sean Posted April 28, 2008 Share Posted April 28, 2008 My brother in law who a landscape contractor and former mechanic has just traded a load of landscaping for a 50T press and a 2 post lift! Made maintenance of my vehicles much easier, not got press over 10T yet though. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 28, 2008 Share Posted April 28, 2008 Hi Try and avoid getting one of the ones which is a bottle jack with return springs, they are rubbish, get one with a proper ram like the machinemart ones, if your patient you can geta nice sealy one off ebay for the same as a clarke one from mm, I too have had the joy of maxing out my friends press on the a frame bushes, dont know what rating it was but its in a factory that makes factories and its about the size of a small van! gas axe fixed it though Mike Quote Link to comment Share on other sites More sharing options...
Marco Posted April 28, 2008 Author Share Posted April 28, 2008 HiTry and avoid getting one of the ones which is a bottle jack with return springs, they are rubbish Just bought one of those...... Would not buy it again (as it is not very accurate) but I di manage to get some bushes out and in :-) Quote Link to comment Share on other sites More sharing options...
