Les Henson Posted December 13, 2005 Share Posted December 13, 2005 Can someone give me the dimensions of a 200TDi intercooler please? Not exact, but pretty close. I need to work out how to fit it in catflap. Thanks muchly. Les. Quote Link to comment Share on other sites More sharing options...
Tonk Posted December 13, 2005 Share Posted December 13, 2005 standard is about 350*200*80 ish i think, only guessin so not much help really Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2005 Share Posted December 13, 2005 (edited) Can someone give me the dimensions of a 200TDi intercooler please? Not exact, but pretty close. I need to work out how to fit it in catflap.Thanks muchly. Les. 460mm including mounting pins 210mm across widest part 185mm front face to lower pipe connection rearmost edge. it's been cleaned as promised & ready to fit Edited December 13, 2005 by western Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 13, 2005 Author Share Posted December 13, 2005 it's been cleaned as promised & ready to fit Thanks Ralph. Could you polish visible parts of it as well. The upper pipe because you will be able to see it when the bonnet is up. Also the back face so that it glitters through the grille. If any of the fins are distorted, could you straighten them up again (tweezers should do the job). Thankyou very much Les. Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2005 Share Posted December 13, 2005 Thanks Ralph. Could you polish visible parts of it as well. The upper pipe because you will be able to see it when the bonnet is up. Also the back face so that it glitters through the grille. If any of the fins are distorted, could you straighten them up again (tweezers should do the job). Thankyou very much Les. Bl&4DY HELL don't want much do you, I'll gold plate it as well NOT Quote Link to comment Share on other sites More sharing options...
