peterdug Posted April 30, 2008 Share Posted April 30, 2008 I'm just starting to build a 90 300 tdi on a richards galvanised chassis. As this is a vehicle i intend to keep for a long time i want to use stainless steel nuts and bolts, does anybody know a supplier in the midlands area and also what sizes i will need and how many of each so i can start getting some prices, i have seen a few kits on e-bay but i'm thinking i must be able to get them cheaper from other sources, thanks for any help. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 30, 2008 Share Posted April 30, 2008 I wouldn't use SS bolts for any fixing that is taking any kind of weight/strain at all. Use proper high tensile bolts. Copper grease the shanks and thread lock the threads. mike Quote Link to comment Share on other sites More sharing options...
peterdug Posted April 30, 2008 Author Share Posted April 30, 2008 I wouldn't use SS bolts for any fixing that is taking any kind of weight/strain at all.Use proper high tensile bolts. Copper grease the shanks and thread lock the threads. mike Are ss bolts not as strong, i thought they were rated in the same way as HT bolts. Quote Link to comment Share on other sites More sharing options...
draper40 Posted April 30, 2008 Share Posted April 30, 2008 Whereabouts in the midlands are you? Helps if you fill in your profile! Pete Quote Link to comment Share on other sites More sharing options...
peterdug Posted April 30, 2008 Author Share Posted April 30, 2008 Whereabouts in the midlands are you?Helps if you fill in your profile! Pete Yes i really should do that i'm near solihull mate, not far from you. Quote Link to comment Share on other sites More sharing options...
white90 Posted April 30, 2008 Share Posted April 30, 2008 the bolts won't rust away like the chassis did. standard H/T bolts will be fine Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2008 Share Posted May 1, 2008 Is there a Screwfix near you? They sell a wide range of standard size bolts in stainless, BZP, brass, and plain steel. Les. Quote Link to comment Share on other sites More sharing options...
peterdug Posted May 1, 2008 Author Share Posted May 1, 2008 Is there a Screwfix near you? They sell a wide range of standard size bolts in stainless, BZP, brass, and plain steel.Les. Yes, one has just opened, i saw the signs for it the other day . Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2008 Share Posted May 1, 2008 Midlands Solihull Screwfix Ashbourne Way Shirley Solihull B90 4QU Opening Hours Mon – Fri 7am – 8pm Sat 8am – 6pm Sun 10am - 4pm Bank Holiday Monday May 5th 8am – 6pm Les Quote Link to comment Share on other sites More sharing options...
peterdug Posted May 1, 2008 Author Share Posted May 1, 2008 Les Is there anywhere that has diagrams of a 300 tdi defender and shows what bolt sizes go where ? I'm building from scratch so any diagrams would be useful, thanks. Quote Link to comment Share on other sites More sharing options...
