Les Brock Posted August 12, 2005 Share Posted August 12, 2005 Starting to put the engine back together, now we hit a problem Haynes..... 200Tdi- 40nNm 60+60 Degs 300Tdi 40Nm 60+60+20 degs (on the last all except the M10 bolts) Label with the New head bolts.... 40nNm 60+60 Degs (only lists the 300Tdi although the bolt lenths are the same) Pic from Western from manual 40nNm 60+60 Degs Now when I put it on last time whereever I got the info from said to eatra 20 Degs So....... does anyone have the difinative, correct, most likely, not going to be wrong, sure as sure can be, absolutly no doubt whatsoever answer ?????? for my 200TDi ASAP please, I'm waiting to tighten it down.... Quote Link to comment Share on other sites More sharing options...
ibexman Posted August 12, 2005 Share Posted August 12, 2005 Hi LES 60+60 total 120 straight from LR manual good luck this time Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 12, 2005 Share Posted August 12, 2005 Les, From genuine manual:- Lubricate bolts with light oil and torque to 40NM. Then 60 degree on all bolts, then 60 degrees. I take it you've got the correct tightening sequence! Cheers Jon Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 12, 2005 Author Share Posted August 12, 2005 Thanks guys, 40Nm 60 + 60 it is then, Yep got the right sequence Here we go again hopefully for a bit longer this time Quote Link to comment Share on other sites More sharing options...
SiWhite Posted August 12, 2005 Share Posted August 12, 2005 If it's any help mine got the 40nm then 60 deg then 60 deg treatment. Good Luck Les-age. Be great to see you at Tony's under your own (cloud of) steam! Si Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2005 Share Posted August 12, 2005 (edited) the info from said to eatra 20 Degs for 300Tdi only on the 10 x M12 bolts Pic from Western from manual --- 40nNm 60+60 Degs That'll be this page then Edited August 12, 2005 by western Quote Link to comment Share on other sites More sharing options...
