'97 V8 Disco electrics
herbert
Does anybody know why the +ve feed to the coil is black? Isit a straight feeed from the ignition switch or is there a resistor link wire? My coil is terminal and I have super mega something or other that requiers a ballast resistor.
Tried the Land Rover CD. No traditional wiring diagram so I am lost. :(
It may be different if yours is a funny one like NAS spec but if it is a UK spec or similar with the std 14CUX injection system then you can feed it 12V straight from the battery with no problems as I had a jump lead made up to go to it when I had a problem on mine. It does not go straight from the ignition but through the "spider" unit (immobiliser related - search on here for more info).
