Ivan Posted May 21, 2008 Share Posted May 21, 2008 I have a Milemarker winch that I want to fit to my 90 using an ARB winch bumper. Problem is the mountings on the Milemarker point towards the floor. Whereas the winch bumper is designed to take a forward mounting winch. Can you rotate the end caps on a milemarker ? If I fit it facing forward one of the levers will be underneath the winch and so inaccessible. Thnx Ivan Quote Link to comment Share on other sites More sharing options...
Lars L Posted May 21, 2008 Share Posted May 21, 2008 No "floor" to drill some holes in? Quote Link to comment Share on other sites More sharing options...
Ivan Posted May 21, 2008 Author Share Posted May 21, 2008 Not with the ARB winch bumper. Ivan Quote Link to comment Share on other sites More sharing options...
SiWhite Posted May 21, 2008 Share Posted May 21, 2008 How about turning the winch around i.e the motor will be on the other side of the fairlead. You might need longer hoses. Quote Link to comment Share on other sites More sharing options...
Ivan Posted May 21, 2008 Author Share Posted May 21, 2008 Good point Si, hadn't thought about that. It needs replumbing anyway as I am going to run it from a PTO. Thnx Ivan Quote Link to comment Share on other sites More sharing options...
Escape Posted May 21, 2008 Share Posted May 21, 2008 Isn't it possible to turn the gearbox with respect to the moubts, so the gearlevers will remain in the correct position? Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted May 21, 2008 Share Posted May 21, 2008 You can mount the winch any way up that you like but unfortunately the gear levers will always be in the same location relative to the mounting bolt holes- the levers do rotate though 360 degrees in the locations they are in if that helps any? Also if it helps then it makes no difference to have the motor on the left or the right hand side of the vehicle, and the motor can also be unbolted and turned through 90, 180 or 270 degrees if if helps with routing pipework. Quote Link to comment Share on other sites More sharing options...
