MogLite Posted December 21, 2005 Share Posted December 21, 2005 I'm gonna try and do an air-actuated PTO lever. I've got myself a suitable cylinder - dual action, which I assume will push and pull. As far as I can tell, there are just two ports on the cylinder - a push and a pull. I want a spool valve that is detent'd so that one position is PTO engaged, and the other is dis-engaged But the spool valves make no sense to me, 2 position detent I've got, but 3 ports/ 5 ports I've got no idea. I can get this range local from Hypose Can anyone tell me which one I need, and why ? I need to do the lockers on the 'Mog axles in a similar way, so I might as well get my head around the pneumatics stuff. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 21, 2005 Share Posted December 21, 2005 Yes But best you ring me tomoorow for a chat, I'll PM you my mobile, also have yer any photos to post ? Nige Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 21, 2005 Share Posted December 21, 2005 5 Port / 2 Way. Air in on one port and depending on position (2 pos) directed down one of the two pipes to your actuator. The unpressurised pipe will be connected by the switch to either of the last two ports to let it exhaust. Quote Link to comment Share on other sites More sharing options...
MogLite Posted December 22, 2005 Author Share Posted December 22, 2005 YesBut best you ring me tomoorow for a chat, I'll PM you my mobile, also have yer any photos to post ? Nige Nige I'll give you a bell a bit later - its early for some at the moment, and I've had a lie-in and done my 2hr commute already Pictures - of the cylinder ? Described as SMC PNEUMATIC DOUBLE ACTING SINGLE ROD CYLINDER PART NO - CDG1BN32-75 32mm BORE 75mm STROKE Quote Link to comment Share on other sites More sharing options...
MogLite Posted December 22, 2005 Author Share Posted December 22, 2005 5 Port / 2 Way.Air in on one port and depending on position (2 pos) directed down one of the two pipes to your actuator. The unpressurised pipe will be connected by the switch to either of the last two ports to let it exhaust. Yeah I think I've got that .... So that makes it this one ? Spool Valve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 22, 2005 Share Posted December 22, 2005 Andy, I have some blingy pneumatic porn catalogues at home from these people: www.westgroup.co.uk they do some very nice valves that look like normal electrical switches. I'll bring them along to the next club meet unless you want them sooner for some reading during the Queen's Christmas Message? Quote Link to comment Share on other sites More sharing options...
Bush65 Posted December 22, 2005 Share Posted December 22, 2005 As above, you will want 2/5 valve. Spool valves are not the best for pneumatics though. Better to use poppet type valves with rubber seats. Quote Link to comment Share on other sites More sharing options...
