Wattle Posted June 16, 2008 Share Posted June 16, 2008 I have a 1956 86" series 1, it has the 2 litre petrol engine and dynamo fitted. I am trying (without any success) to fit a new fan belt. The belt that came off is the same as the one going on, it has GFB 40995 marked on both of them. I think this is a Unipart number for this model. I struggled getting the old belt off even though it was stretched and badly split, and the dynamo is as far back as possible. The new belt just does not look long enough, it could do to be an inch or two longer. Is there a method of fitting them other than brute force, because i have already tried that. Or is there a longer belt that is available. Thanks Phil Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2008 Share Posted June 16, 2008 I don't know if there's more than one size, but I do know they are hard to get on due to thickness of them and the 'v' in the pulley. Try unbolting the dynamo altogether and once the belt is on - put it back in place. Les. Quote Link to comment Share on other sites More sharing options...
80INCH Posted June 16, 2008 Share Posted June 16, 2008 They are a bit of a bugger to put on aren't they! Yes it may be easier to unbolt the dynamo; then put it in position before bolting it back. i think thats what i did because its so thick the regular way is just to difficult.. i managed to do it once with screwdrivers as levers pulling it round the pully from underneath tho. Quote Link to comment Share on other sites More sharing options...
HoggyN Posted June 17, 2008 Share Posted June 17, 2008 I seem to remember having to unbolt the fan pulley to get a new fan belt on - although why I did that and not just unbolt the dynamo is beyond me! Quote Link to comment Share on other sites More sharing options...
Wattle Posted June 19, 2008 Author Share Posted June 19, 2008 Well I removed the dynamo, I can just manage to get the belt in the dynamo groove. But no chance what so ever of refitting the dynamo bolts, it no way near. I think the belt that I removed was split because it had been to tight. I have been to Fenners who specialise in belts, and there is none anywhere near this size, they are all a lot longer. Could the pulleys be too big? Any ideas please. Surely people haven't struggled like this for the last fifty years. Phil Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2008 Share Posted June 19, 2008 Perhaps you can stretch the new belt a bit - prior to fitting it? Loop it under a jack and over the top and then rasie the jack. I suppose it depends on how much it needs to be stretched to get it to fit. Les. Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted June 20, 2008 Share Posted June 20, 2008 Alternatively, find a bottom pulley off a 6-cylinder and water pump/alternator pulleys off a 2.25 then you can fit the narrower fan belts which are much more common and only a couple of quid each (and easier to fit). Quote Link to comment Share on other sites More sharing options...
80INCH Posted June 20, 2008 Share Posted June 20, 2008 are you sure you have the right belt? where did you buy it from. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted June 20, 2008 Share Posted June 20, 2008 I refitted the old belt to my 80 inch the other day. Even with no radiator it wasn't easy but I put that down to the pulleys being freshly painted. Looks like a new one would be difficult and might well require more than the obvious dismantling - like removing a pulley. Quote Link to comment Share on other sites More sharing options...
Wattle Posted June 25, 2008 Author Share Posted June 25, 2008 Now sorted. i got a new belt from Dunsfold and it was 3 3/8"(thats 85mm) longer than the GFB40995 belt (which is the Unipart equivalent). Fitted easily. A big thanks to Dunsfold Land Rovers and everybody who replied. Thanks Phil watson. Quote Link to comment Share on other sites More sharing options...
