HPLP Posted June 19, 2008 Share Posted June 19, 2008 Hello all, I thought Id post this up. I have recently fitted a VDO tachometer to my 90 tdi and it seems to read very low. Its fed off the W terminal on the back of the alternator. Is there any adjustment on them as at idle it sits at about 500 rpm and flat out is only about 3000rpm. Any thoughts would be greatly apreciated! H Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2008 Share Posted June 19, 2008 See my reply in this rev counter thread Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 19, 2008 Share Posted June 19, 2008 If it's the same as mine, the adjustment process was fully described in the fitting instructions. There are three DIP switches and a fine-tune pot on the side of the unit. the DIP switches set the rough range and the pot is for fine adjustment. Edit: D'oh, Ralph beat me to it. Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2008 Share Posted June 19, 2008 Didn't touch the fine adjustment on mine, the 3 slide switches got it almost spot on & that's how it has stayed. Quote Link to comment Share on other sites More sharing options...
HPLP Posted June 19, 2008 Author Share Posted June 19, 2008 Do you mean that there was adjustment on the back or actually behind the cover as all thats on mine is the 3 connectors on the back, and 3 screws which I assume are for holding the body on. H Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 19, 2008 Share Posted June 19, 2008 On the side, IIRC. Quote Link to comment Share on other sites More sharing options...
HPLP Posted June 19, 2008 Author Share Posted June 19, 2008 Looks like I'll have to crack open the cover/case and see whats in there. Thank you, H Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 19, 2008 Share Posted June 19, 2008 What is the tacho in? a single enclosure by the sounds if it? if you've got the actual tacho in your hands, you don't need to remove any cover at all to find the switches, unless you have the wrong unit. though I'd expect a petrol tacho to still have dip switches to select the number of cylinders. Quote Link to comment Share on other sites More sharing options...
HPLP Posted June 19, 2008 Author Share Posted June 19, 2008 I'll go and take it out of the dash and take a piccy. It definately works on the feed from the alternator so thats what i was puzzled by...... H Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 19, 2008 Share Posted June 19, 2008 Is this a "normal" aftermarket VDO tach or one from a TD5? Only the aftermarket ones are adjustable. Quote Link to comment Share on other sites More sharing options...
HPLP Posted June 19, 2008 Author Share Posted June 19, 2008 I have no idea if its a td5 one tbh......I just bought it at a boat jumble a few months ago. Ive just taken the screws out and they seem to just hold the inner assembly......hmmmmm H Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 19, 2008 Share Posted June 19, 2008 Mines the same with no adjustment facility. Mine however sits at a tad below 750 at tick over. Can you get to 3000 in a tdi ? Mo Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 19, 2008 Share Posted June 19, 2008 Yup that's a different unit to the VDO tacho i have. Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2008 Share Posted June 19, 2008 Totally different to mine [which is the 50th anniversary V8 version] a Tdi should rev to 3850rpm with no load on, i.e. not moving the vehicle just revving from tickover while stationary. Bosch call it the 'flight speed' Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 19, 2008 Share Posted June 19, 2008 Mines the same with no adjustment facility. Mine however sits at a tad below 750 at tick over. Can you get to 3000 in a tdi ?Mo Certainly. 200TDIs governors are at 3750. They should rev and power freely up to there. 3000 rpm is 72 mph in a normal stock TDI in 5th gear. Quote Link to comment Share on other sites More sharing options...
HPLP Posted June 19, 2008 Author Share Posted June 19, 2008 Aye, well flat out in second with lots of black smoke out the back is 3k on this one. As i paid all of £15 for it, i think that I'll just use it and add it up in my head. Many thanks for your thoughts though..... H Quote Link to comment Share on other sites More sharing options...
m0bcg Posted June 20, 2008 Share Posted June 20, 2008 AUTOGAUGE 52mm DIESEL TACHO + FITTING KIT+ POD Item number: 360062318193 see ebay , item number shown above . i have one on my 300tdi fed from alternator W terminal . 0-6000rpm scale easy fitment, easy to synchronise and adjust with screwdriver via one single trimmer pot in back of unit . can set revs infinitely to suit any diesel engine that has a w terminal on alternator . why pay silly money for a vdo gauge when you can get all you need in this one above, this even comes with a 2" mounting pod included in the price . Aye, well flat out in second with lots of black smoke out the back is 3k on this one. As i paid all of £15 for it, i think that I'll just use it and add it up in my head. Many thanks for your thoughts though..... H Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 20, 2008 Share Posted June 20, 2008 why pay silly money for a vdo gauge when you can get all you need in this one above, this even comes with a 2" mounting pod included in the price . Well let's see... 1) That one costs more than a VDO. 2) The colour scheme looks nothing like the stock gauges. 3) 6000 rpm is much higher than needed. a 4000 rpm VDO Vision is perfect. Quote Link to comment Share on other sites More sharing options...
