Petergg Posted December 31, 2005 Share Posted December 31, 2005 Hi, Need the settings for Defender 90 td5 diff please. Bearing caps. Pinion Bolt. Crown wheel Bolts. Regards Peter Quote Link to comment Share on other sites More sharing options...
John_T Posted December 31, 2005 Share Posted December 31, 2005 Peter, My TD5 manual does not give the figures. However, Iam told that the crownwheel and cap bolts are the same as for the TDi (unless you are talking about the 110 rear diff). The pinion bolt is 100 nm. John Quote Link to comment Share on other sites More sharing options...
Petergg Posted December 31, 2005 Author Share Posted December 31, 2005 Peter, My TD5 manual does not give the figures. However, Iam told that the crownwheel and cap bolts are the same as for the TDi (unless you are talking about the 110 rear diff). The pinion bolt is 100 nm. John Thanks John, we must have the TD5 manual. Peter Quote Link to comment Share on other sites More sharing options...
