Defenderman1980 Posted June 27, 2008 Share Posted June 27, 2008 Hey folks, this is my first post on here so this may be a stupid question, but i am away to have a look at a 2002 TD5 110 Defender tomorrow and i was wondering if you guys would know what to look for in this particular model with regards to faults etc? At the moment, my wife is running a 03 Freelander (1.8 petrol and yes, the head gasket has gone! ) but i need something a bit bigger so i think the 110 is the way to go. Any advice would be greatly appreciated. Cheers, Scotty. Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted June 27, 2008 Share Posted June 27, 2008 Ian (Porny) gave me the following advice about the TD5 engine: Things to check (engine wise) are.... Oil in the red plug at the ECU (injector loom as mentioned) Leaking fuel regulator (rear of the RHS of the engine block - just below the rear of the inlet manifold) Siezed turbo wastegate/actuator Incorrect ECU replacement Corroded radiator Check mill lamp works (should come one when you turn ignition on, then go out) Seized EGR (someone might sell a removal kit :rolleyes:lol ) Juddering clutch/odd noises at idle And if you have access to a diagnostic computer: If post 2002 check VIN number in ECU matches the vehicle VIN Check the Air Flow Meter works Have a look at cylinder compensation values Check boost pressure And look at any fault codes. Quote Link to comment Share on other sites More sharing options...
Defenderman1980 Posted June 27, 2008 Author Share Posted June 27, 2008 Superb. Thanks for that. All going well, i will be able to post a couple of pics of my new purchase just shortly!! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 27, 2008 Share Posted June 27, 2008 It's not a stupid question, Defenderman, it's a very sensible one Welcome to the forum Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted June 27, 2008 Share Posted June 27, 2008 Welcome Quote Link to comment Share on other sites More sharing options...
Defenderman1980 Posted June 28, 2008 Author Share Posted June 28, 2008 Thanks Mo. Quote Link to comment Share on other sites More sharing options...
